Slime in tubes?
19 replies to this topic
  • jcbikes
Posted March 16, 2010 - 02:42 PM
Anyone have any luck using slime in their tubes? Was wondering the Pro's or Cons"s to using this product.
  • Stickshift
Posted March 16, 2010 - 04:23 PM
If you are riding in lots of rocks, or areas with bad thorns, it is definitely a good idea to run Slime in tires with tubes. It's a little irritating when you check the air pressure, you get a little Slime in your air gauge, but otherwise it's great. Heavy duty tubes are also important for this kind of duty.
Note there are several related threads if you do a TT search.
Cheers,
BG
  • jcbikes
Posted March 17, 2010 - 06:22 AM
Thanks BG. Riding here in Colorado, you are basically riding on and over rocks all the time. Not called Rocky Mountains for nothing. Concerned about pinch flats from the rocks.
  • KennyMc
Posted March 17, 2010 - 07:12 AM
IMO the best prevention for pinch flats are Ultra Heavy Duty tubes and tires with stiff sidewalls (Maxxis Desert IT for rear and Pirelli XCHM for the front).
The Tubliss system is probably the best, just a bit more $$
  • ajh42e
Posted March 17, 2010 - 07:42 AM
There is a new product out called Ride on. www.Ride-on.com This stuff is awesome. It cost a lil more then slime but makes no mess, works on tube & tubeless tires and Balances your wheel so you dont have to have to worrie about wheel weights getting Knocked off! I have ran a lil over 100 mph on my 690 ktm with no Vibes or any thing. Read up on this stuff and make up your own mind. I did and now a believer!
AJ
  • Vmax540
Posted March 17, 2010 - 09:17 AM
NOTE: For Severe apllications (offroad/motorcross)
you may add 45% more product. Please Note: at these higher dosages you may experience some vibrations at high speeds.
  • jcbikes
Posted March 17, 2010 - 07:12 PM
Thanks guys. I will check out the ride on stuff. do you know where you can purchase it at?
  • jcbikes
Posted March 17, 2010 - 07:16 PM
I see that it is not in the state of Colorado and will have to be ordered online.
  • kwar63
Posted March 18, 2010 - 06:13 AM
I put slime in my tires once for a Texas Big Bend ride. I did not have any problems and no flats. However, when I got home and rode the bike on the street. The slim definitely messed up the handling and there was additional vibration. It really made the bike feel weird in corners on both dirt and street. 2 months after putting the slime in I replaced both intertubes to get rid of the handling problems. I will never put slim in my tubes again. I did not like the handling and the vibration issues.
Kurt
  • CORider63
Posted March 18, 2010 - 06:19 AM
Slime almost never seals pinch flats.
The best guard against pinch flats is fresh tires with stiffer sidewalls and adequate air pressure for the conditions and speed.
Properly setting up your suspension helps, as well.
  • wondermuscle
Posted March 18, 2010 - 06:48 AM
I have been using this white stuff that I get at auto part stores. I think it is teflon based and does a MUCH better job than slime. It will actually mend a pinch flat and will seal a tube that has been ravaged with catus.
http://www.napaonlin...6601_0238940391
But there is no susbstitute for a good HD tube and a fresh front tire.
  • zukrider
Posted March 18, 2010 - 03:17 PM
If you do get a flat that the slime won't fix you are out of luck. You can't patch a tube with the slime in it. At least the two times I have tried the slime messes with the glue and won't let it stick.
  • jcbikes
Posted March 19, 2010 - 06:59 AM
I think slime is out. I ride the bike on the street and do not need those problems.
  • pablo83
Posted March 26, 2010 - 02:22 PM
I used slime for years. It never seemed to stop a flat. Haven't had much luck with thick tubes either. I just carry tools and tubes.
  • justbackitin
Posted March 26, 2010 - 04:59 PM
I've tried it many times on my ice racing tires since they are really difficult to change. Slime has never worked for me. I'm 90% sure it has to do with the white powder that seems to come in tubes.
  • Baja trail Rider
Posted March 27, 2010 - 07:37 AM
We have been using slime on our dirt bikes for tours for over 10 years.We use bridgestone ultra heavy duty tubes.The bikes are used for tuff single track trails,we use 5-7psi.For this type riding the stiff side wall tires dont work.In Baja flats are a plenty.Some times they still go flat because low psi wont push the slime past hole.So on trail I pump up tire to 15 or more psi,ride a mile or so.Then let tire back down,only once did not work,it was getting dark.So I put 8 more onces in on the trail,that got it.I dont notice handling problems,sometimes we ride a few miles on pavement.
  • OUTERLIMITS
Posted March 28, 2010 - 09:48 AM
As Baja Trail Rider mentioned, Bridgestone ultra heavy duty tubes are your friend and I feel the best out there. Also as noted, slime can't always help you with a pinch flat so a stiff carcassed tire and the ultra heavy duty tubes are the best starting point. I always use slime as my most common flat (not very often!) is nails or cactus and it does a great job on those types of holes. With slime, at times I have only discovered that I had a flat when I went to go change the tire and could see a little bit of the green goo on the inside, but never lost any pressure. Also to note, the kind of slime made for tubless tires (it's got bigger chunks of "stuff" in it) still seems to work well in tube type tires, maybe even better than the other stuffl.
  • Baja trail Rider
Posted March 29, 2010 - 08:11 AM
That is a new one on me,as I used the tubeless slime one time.( by mistake) did not work well.I also used, cant think of name its yellow in color like slime it has worked good also.
  • phynx
Posted March 30, 2010 - 09:09 AM
Kurt
I have ran slime in both street (running @90mph, no prob) and dirt with no problems. It may have been that you put the whole bottle into the tube or tire, or just too much. And putting that amount of any liquid into a tire will be a problem. I have always just put a minimum. But yes, I have heard of this complaint before.
  • desdave
Posted April 07, 2010 - 01:23 AM
So Cal desert racing involves lots of rocks. General practice here is all the basic stuff mentioned...tires with a stiff sidewall (Maxxis has become the tire of choice over the last 5 years or so), slime, heavy duty tubes and run the air pressure a little high, I have always run 16 front and rear. Still there is no sure way to never have a flat unless you run the solid inserts. Slime will only slow a small puncture hole not a pinch tear.
