yz450f road gearing and top speed
10 replies to this topic
  • adamshackleton
Posted March 12, 2010 - 02:31 PM
hi guys,i have just bought a yz450 supermoto to use on the road,now either my speedo is set up wrong or the gearing for the road is way out,currently running 14 front and 36 rear and bike is screaming flat out at 65mph where as my brothers 426 flies beyond 90mph,what top speed should i expect from this bike? and what gearing would you guys recommend? thanks
  • FinchFan194
Posted March 12, 2010 - 02:48 PM
What year is it?
  • mikedabike
Posted March 12, 2010 - 10:56 PM
Something is wrong 14/36 on any YZ450 is well over 100 MPH even with 17" wheels. Are you sure it is a 36? I did not think you could go that small and still have the chain track correctly through the guide.
  • Polar_Bus
Posted March 13, 2010 - 04:50 AM
Yup, I agree.
My stock geared '07 will pull about 83 mph on the ice via GPS
If that is in fact a 36T rear sprocket, my guess is the engine is incapable (torque) to pull that high of gearing....
as a comparison, with my KX500, anything smaller than a 42T rear, I start to feel the peak rpm's really flatten out and lag...
  • FinchFan194
Posted March 13, 2010 - 11:08 AM
Yup, I agree.
nevermind. . .
  • adamshackleton
Posted March 13, 2010 - 11:37 AM
chain tracks fine and is def 36 rear and 14 front but tops out on rev limiter at 65mph,feels about that fast to but guess i should check the vapour speedo is correct(set up correct with right wheel size programmed in) through the gears is smooth and very powerfull giving her beans so cant really se as anything is wrong engine wise,mind, it is very easy to stall with this gearing
  • adamshackleton
Posted March 13, 2010 - 11:38 AM
2003 mate
  • Michigantrailrider
Posted March 13, 2010 - 05:13 PM
For what it's worth, the 2003 is a four speed so I can understand how it is hard to get high top end speed. It was geared for motocross where the high top speed was not that important. I run a 16 on the front and a 45 on the rear for my road setup, but I am not concerned with going that fast either. My buddy has a YZ 426 that is a 5 speed and he has much more top end.
Posted March 13, 2010 - 07:01 PM
A stone stock '03 will exceed 80 mph on dirt easily. I know because mine did. If you are hitting the rev limiter that soon, check for a short in the neutral switch circuit (unplug the CDI, with the bike in gear and check continuity to ground from the light blue lead running to the switch. It should be open ; no continuity in gear, grounded in neutral).
If this circuit grounds while in gear, the rev limit will be cut to 7000
  • FinchFan194
Posted March 13, 2010 - 09:47 PM
Now that makes since Gray as to the OP's problem.
  • adamshackleton
Posted March 14, 2010 - 03:31 AM
i have a spare 45 rear and a 50,guess i'll try the 45 and see what difference that makes,should i go any smaller or bigger than the 14 on the front?
  • Hot  113 replies
  • Hot  36 replies
