Best Place for temp strip
9 replies to this topic
  • 426 NOOB
Posted March 11, 2010 - 02:00 PM
I know that when the coolant is over 250 degrees F you are too hot but what about the temp for the side of the head. Im trying to determine the best place to put my new temp strip, or better yet most accurate place, so that I can visually see motor temps. I thought I saw a thread on the most accurate place a while back but could not find it today. Thanks:worthy:
Posted March 11, 2010 - 02:32 PM
Either the side of the head or one of the upper radiator tanks. BTW, assuming you use a 50/50 mix of common EG coolant and water with a 16 lb (1.1 bar) cap, 250 (℉) isn't actually too hot, but it's getting close. At 3000 feet or less, that should boil at 265, so "too hot" is at that point. Still, it's prudent to stop heating it up at 260 or sooner.
  • 426 NOOB
Posted March 11, 2010 - 02:38 PM
i run engine ice with a stock cap. Thanks gray
Posted March 11, 2010 - 03:08 PM
The stock cap is a 1.1 bar cap. With Engine Ice (PG based) the boil point should be about 5 degrees higher.
  • 426 NOOB
Posted March 11, 2010 - 09:05 PM
thanks gray.:banana:
  • Scrubba
Posted March 12, 2010 - 01:43 AM
is engine ice less protective to the water pump/seal, than coolanol?
Posted March 12, 2010 - 07:41 AM
Six of one, half-dozen of the other. In that regard, there's little difference between ethylene glycol based coolants such as Coolanol and propylene glycol coolants like Engine Ice. In fact there's not much of a distinction between them at all, as far as how or how well they work when fresh.
EG coolant is extremely toxic, PG coolants are considered non-toxic (don't drink any).
PG coolants oxidize more rapidly, which forms lactic acid, and it can be very corrosive. All quality PG products include additives to protect the system from this, but it should still be changed out annually at the least just to be safe.
Neither is a really good lubricant, but both are better than plain water on that score.
  • Scrubba
Posted March 12, 2010 - 02:18 PM
ok thanks, always wondered about that:thumbsup:
  • davidrussell41
Posted March 12, 2010 - 04:33 PM
Is there a company that makes a radiator cap with less pressure? I run Evans cooling system coolant and it boils a 385 with no pressure. Was curious if anyone made one.
Posted March 12, 2010 - 07:32 PM
Why would you want that?
  • Hot  28 replies
  • 9 replies
  • On January 15, 2017
  • Hot  36 replies
  • Hot  113 replies
