Electrical current through levers..... ?
12 replies to this topic
  • sasreg
Posted March 09, 2010 - 07:03 PM
Hey guys,
08 WR450F Aussie Spec.
Need some advice on where to start -
While out riding I have noticed an intermittent electrical current current going through my clutch and front brake lever (maybe the whole frame, but my hands are the only thing that feels it). I'm not sure where to start. Has this happened to anyone else? It makes it pretty difficult to feather the front brake when the current causes muscle contraction :banana:
Any help would be appreciated.
Cheers.
  • CORider63
Posted March 10, 2010 - 05:51 AM
I've had issues with static electricity "shocks" if it's REALLY dry and dusty. Especially if you have plastic hand guards.
Edited by CORider63, March 10, 2010 - 07:57 AM.
  • Butta
Posted March 10, 2010 - 08:29 AM
Place some electrical tape UNDER the engine cut-off switch (wrap tape around the handlebars where the kill switch mounts) and you should eliminate that problem. It happened to me on my WR400 when WOT in the desert....sucks to be "bitten" like that at high speed!
  • KennyMc
Posted March 10, 2010 - 09:34 AM
I will have to give that a try. Pretty funny, I thought it was just my bike:bonk:
  • Flooder305
Posted March 10, 2010 - 10:08 AM
After that just start chasing the wiring looking for any exposed wires.
  • sasreg
Posted March 10, 2010 - 12:47 PM
Cheers guys. Much appreciated. I just wanted to make sure there were no known problems before I started tearing her apart. Thanks for the info. :banana:
  • trancetechau
Posted March 10, 2010 - 10:30 PM
i have the same issue on an aussie 2009 model! I still haven't found the solution. I will try "Place some electrical tape UNDER the engine cut-off switch (wrap tape around the handlebars where the kill switch mounts) and you should eliminate that problem".
  • WR450FGreg
Posted March 10, 2010 - 10:55 PM
If it's any consolation, my '08 has the same issue, apparently .....
it only happens (sometimes) when other people ride it believe it or not.
I have never felt it!
I put it down to damp (sweaty) gloves or something.
I've never bothered to try and fix it because, as I said, it has never happened to me!
Greg
  • snorter
Posted March 11, 2010 - 02:18 AM
I have a 2008 wr450f and i had to disconnect the front brake light switch from under the headlight to stop the electrical shocks. Very off putting when you are hard on the anchors.
let us know if you find the answers so i can fix my bike properly
Evan
  • JDLowrance
Posted March 11, 2010 - 07:00 AM
It's definitley related to the ADR street legal kit in Aus. Not heard of this issue any where else.
  • KennyMc
Posted March 11, 2010 - 10:00 AM
Hmmmmm, could be on to something. I have a dual sport kit on my bike.:banana:
  • timoyz1
Posted March 11, 2010 - 10:04 AM
I don't have a DS kit on mine, and it was happening to me. I didn't do the tape thing, but it was something with the kill switch. Once I took it apart, cleaned it, and reassembled it, the problem was solved. :banana:
  • Butta
Posted March 11, 2010 - 01:10 PM
I should add that my shocks were coming from the ends of the grips, where they had been cut due to the addition of the hand guards. I also taped that exposed handlebar/handguard junction and I had no further festivities....
