2010 YZF 450, light & nervous frontend...
8 replies to this topic
  • Swiss_Dirtrider
Posted March 08, 2010 - 09:33 AM
Hi everybody
I was a longtime 250F Kawasaki rider and changed to 450 now. I buyed the new Yami 450 and i am very happy with it!
My only problem i have is in deep, muddy and rutted conditions. I was pretty good in that kind of tracks with my 250F, it was my favourite terrain. But now with the 450 the front end feels so light and nervous. The frontwheel takes and follows every rut, and the bar pulls in every direction. I had 2 crashes because i wasn't prepared that the bike will pull left on a 3rd gear rutted straightaway...
Maybee it's just me and i have to become more used to the completely new bike (20+ hours yet).
But maybee this is already a known issue with this specific new bike and someone knows a workaround i can try.
I've tried different fork positions (more down in the tripleclamps), it was better, but not much.
I was thinking of a steering stabilizer, but want to try out other things first, if its riding technique or bike-mod...
Any Ideas?
Thanks a lot!
Regards
Oliver
Posted March 08, 2010 - 10:41 AM
A Scotts (or its Ohlins parent) damper is a great thing to have in any case.
That said, check your race, or rider mounted sag. It should be between 98-105 somewhere. If it's less than 105, try increasing it a little. This will increase the head angle a little and help with the twitchy feel.
  • motojase316
Posted March 10, 2010 - 03:20 AM
I had the same light nervous feeling at the start too. I have changed spring rate on the shock to balance out the bike for my weight. I also mounted up a GPR V4 steering stabilizer.
All my problems are over. I have ran A scotts damper for over 10 years and now switched to the GPR V4 and I am converted, I am sure others will disagree however I find it a better unit.
  • YamaLink
Posted March 10, 2010 - 05:36 AM
Whoa, that GPR is very very nice looking! Great product from a great company.
+1 on what Grayracer posted.
  • 2milehigh
Posted March 10, 2010 - 09:17 AM
I initially felt the same thing when the bike was new to me. Setting the rear sag at 108mm first and then raising the forks 4mm in the triples helped give the bike a more settled feel. As I've gotten more used to the bike I put the sag closer to stock, at 102mm right now but plan on leaving the forks raised until the WER stabilizer mount is available. The bike also seems to like having the front brake dragged when the front gets twitchy. I'm not an expert at setup but these are the things that have helped me. Good luck!
Posted March 10, 2010 - 09:31 AM
You understand that this is the same as setting the sag at 104mm and leaving the forks flush, right?
  • 2milehigh
Posted March 10, 2010 - 10:57 AM
Wouldn't raising the forks result in a shorter wheelbase?
Posted March 10, 2010 - 11:08 AM
Yes, but not enough to notice. At a 27 degree angle, 4mm would probably only result in a 1mm loss of wheelbase.
However, raising the forks makes the head angle steeper, which works in opposition to increasing the sag, which makes it shallower. These changes are much more noticeable than a shift in wheelbase.
  • wondermuscle
Posted March 10, 2010 - 01:52 PM
Try adding 3 clicks of rebound in the front. It typically helps keep the front end planted in rocks but it might help with bouncing around from rut to rut. Something to try before you drop a bunch of cash on a stabilizer.
