09 yz450 question
10 replies to this topic
  • WR-man
Posted March 07, 2010 - 08:45 PM
hi im new to this form and would like to say hi
I just bought a new yz450 2009 and i haven't broke it in yet. i started it up and it was back firing when i let off the throttle at 1/4 of a throttle
my question is? is that common or is there something wrong . thanks
  • locomike
Posted March 08, 2010 - 03:07 AM
The pilot jet is probably a little lean, since the weather is a little cooler now than the conditions it is jetted for. Try a larger pilot jet.
  • dvn
Posted March 08, 2010 - 03:56 AM
This is most likely true. You can try adjusting the fuel screw first but don't make any adjustments until the bike is fully warmed up.
  • davbrucas
Posted March 09, 2010 - 05:36 AM
Yep...turn the fuel screw all the way in counting the number of full turns...then turn it back out past where it was but no further than 3 full turns to try to make the backfiring go away...if it still does it after this adjustment, then go to a one size bigger pilot jet. I am near sea-level and didnt need a larger pilot jet...just some fuel screw adjustments. You should buy an aftermarket fuel screw to make the adjustments easier.
Posted March 09, 2010 - 08:13 AM
Be sure that you check for exhaust leaks at both ends of the header before playing with the screw. If the backfire is caused by a leak, you'll end up with a bike that idles poorly, fouls plugs, starts hard, and dies when the throttle is chopped. Just sayin'.
  • anthony72
Posted March 10, 2010 - 12:47 PM
I have the exact problem. I have an 08 stock tires and eavrything idle jet all the way. Iv had it a month and it barly ran decent. Don't ride it like that! Iv had mine a week with the jet worked and it's awsom. Easy
  • dvn
Posted March 10, 2010 - 05:29 PM
huh??? :banana:
  • TRIPLE 5
Posted March 10, 2010 - 05:39 PM
huh??? :banana:
:lol:That's exactly what I was thinking.
  • czechalien
Posted March 10, 2010 - 06:49 PM
How do you check it? is it by plugging the end of the exhaust?
If so what should I look for? will the bike stop running?
THX
  • WR-man
Posted March 10, 2010 - 08:42 PM
thanks for the help ill keep you posted i just bought a fuel mix screw today and ill ride tomorrow:thumbsup:
Posted March 10, 2010 - 09:20 PM
THX
You can do it that way, but get it running first. Any leaks should be obvious. But you can also start by seeing if the clamps and flange plate are tight.
  • Hot  47 replies
  • Hot  33 replies
