Difference 06 to 09 header - pics
12 replies to this topic
  • crf450319
Posted March 07, 2010 - 05:52 PM
I've got an '06 header to run on my '09, thought it might be worth posting the pics of the two OEM headers. The 06 header is a little less than an inch and 5/8's, the 09 header is a little better than an inch and 3/4.
Below the pics of the headers is a pic of my '09, I've got everything greased and am starting to put it back together.
  • TRIPLE 5
Posted March 08, 2010 - 02:35 AM
That's exactly what my bike looks like. :banana: Just waiting on some parts so I can put it back together. Can you measure the overall length of the 06 and 09 headers.:lol: You'll need a soft (flexible) tape measure . Thanks.
  • crf450319
Posted March 08, 2010 - 06:18 AM
The headers were the same legnth, when I took the pics they were lined up and at the time I noticed the similarity in legnth. There might be a 3/16" difference at the most, if any difference at all.
What parts are you waiting on ?
  • TRIPLE 5
Posted March 08, 2010 - 02:49 PM
I'm waiting on updated steering stem bearing with seal, 06 header, Radiator cages, NFPR needle, etc.. I like to completely go through all my new bikes and become familiar with them and also fix some things the guys mess up at the dealership:bonk:
  • crf450319
Posted March 09, 2010 - 07:15 PM
I've got the bike almost all put back together, here's what I've done so far :
'06 stock header
'06 Pro Circuit T4 slip-on
'06 CDI
NFPR needle, 165 main jet
Boyesen accel. pump cover
Here's what I'm waiting on :
280mm front brake rotor
xw-ring chain & Ironman sprockets
Used plastic set & seat - I'll put the new stuff away.
Wondering about gearing though, I might ride it with the stock 13/49 then decide what I want to do. Which means waiting on ordering the Ironman stuff. I greased the steering stem bearings the other day, noticed that the seal has a double edge on it - what does the updated bearing/seal have that's different ?
  • cowboyona426
Posted March 10, 2010 - 07:43 AM
Are you an MX guy or a woods rider? For woods you'll want a flywheel weight and lower gearing.
  • crf450319
Posted March 10, 2010 - 09:07 AM
I'm an MX guy, might ride in the woods once every two or three years. I was wondering about putting a little bigger fly wheel weight on. Not something that would make a drastic difference, but I'm guessing there might be something (weight wise) that may give me a little better performance - even on an MX track. I've got to do a little more research on that though..
  • TRIPLE 5
Posted March 10, 2010 - 05:16 PM
DIDO:thumbsup:
Yeah, I'm not really sure about the updated bearing, it was what I was told.
Things I've got so far:
06 Header
Modded stock muffler
06 Cam
50 tooth rear (cheap steel one)
RK520EXW Gold (Do I need a spacer)
Extra set of plastics
Moose radiator cages
Works Connection skid plate
First I'm going to ride it stock to get a base line and then I'll start adding and changing parts to find out what does what. It's a new bike so I need to dail it in, Lots of testing:ride:
  • 4Ds
Posted March 12, 2010 - 06:04 PM
[quote name='crf450319'] The 06 header is a little less than an inch and 5/8's, the 09 header is a little better than an inch and 3/4.[QUOTE]
So why put the smaller header on? Wouldnt the newer 09 thats larger flow better and therefore perform better?:banana:
  • FinchFan194
Posted March 12, 2010 - 07:05 PM
[quote name='4Ds'][quote name='crf450319'] The 06 header is a little less than an inch and 5/8's, the 09 header is a little better than an inch and 3/4.[QUOTE]
So why put the smaller header on? Wouldnt the newer 09 thats larger flow better and therefore perform better?:banana:[/QUOTE]
No the bigger header flows too well once you get rid of the restricted shorty muffler. It takes away from the bottom end so a little bit smaller diameter will give you back the bottom end that is desired for rocketing out of corners.
  • 4Ds
Posted March 12, 2010 - 10:12 PM
I had an 06 and it was an awesome bike, had to sell it though and havent had a bike for a couple years. Did you have an 06 and Is the 09 much different or better?
  • husqy360
Posted March 13, 2010 - 02:34 AM
[quote name='FinchFan394'][quote name='4Ds'][quote name='crf450319'] The 06 header is a little less than an inch and 5/8's, the 09 header is a little better than an inch and 3/4.
No the bigger header flows too well once you get rid of the restricted shorty muffler. It takes away from the bottom end so a little bit smaller diameter will give you back the bottom end that is desired for rocketing out of corners.[/QUOTE]
sound simple, good to know why they actully change some stuff.:banana:
  • TRIPLE 5
Posted March 13, 2010 - 03:10 AM
Just call me the rocketman.:banana: That's what I would like to happen, now all I need is my bike back together and some nice weather so I can start testing.
Motocross
  • Hot  491 replies
  • 9 replies
  • Hot  47 replies
