loctite!
3 replies to this topic
  • 669966
Posted May 25, 2003 - 08:19 AM
to loctite or not to locktite? this is the question! i'm talk'n 'bout the usual fairings, fenders, plastics, and headlight bolts. ya know - the 8mm, and 10mm bolts that are always on, off, on, off, on, off.........! :)
  • Sylvain
Posted May 25, 2003 - 08:39 AM
Depends what type of loctite you want to use.
There is the: removable loctite, threadlocker, medium strenght, high strenght, etc...
If you are referring the a WR or YZ, the owners manual indicates when and where you have to loctite.
Also you have to respect the torque spec, if it still loosen after proper torque, then I'm sure a removable loctite would do a good job. :)
  • oRGie
Posted May 25, 2003 - 11:12 AM
I use the removable blue stuff on all those bolts.. lost a few before I started to do that.. its cheap and doesnt cause any mess or problems, so why the heck not :)
  • adamwagar
Posted May 25, 2003 - 11:28 AM
Blue loctite for sure. Check your sidestand bolts. It's a drag when you lose one on the trail.
