Wr 426 2001
2 replies to this topic
  • sage
Posted March 07, 2010 - 12:47 PM
Hi All.
What would the fork oil level be on these forks plaease, also what wieght oil should be used?
I have never change fork oil in USD forks, do I need to do anything different to conventional forks?
  • umu24013
Posted March 08, 2010 - 12:10 PM
According to the manual, which says:
Standard oil level:
135 mm (5.31 in)
From top of outer tube with
inner tube and damper rod 1
fully compressed without
spring.
Extent of adjustment:
80 ~ 150 mm (3.15 ~ 5.91 in)
I use Motul Fork Oil Expert 5W
  • sage
Posted March 08, 2010 - 01:08 PM
Hi.
Thank you very much for the information, helps me out a lot.
Andrew
