Flywheel Torque- How do I hold it?
3 replies to this topic
  • Guest_Guest_*
Posted April 04, 2001 - 09:35 PM
posted 04-04-2001 07:22 AM
What is the easiest way to hold the flywheel in place while you torque it down? I am going to install a Steahly 14 oz tonight and that is the only thing that bothers me is how to hold it. I don't want to pull the clutch side off and I don't have a clutch holding tool. I'm going to try a strap wrench but any input is helpfull!
I will document the install with my digital camera and post it if anyone is interested.
Roostn in Denver
  • Rick_Graham
Posted April 04, 2001 - 10:02 AM
Put the bike in gear and have somebody stand on the rear brake. Should have enough force to do the trick.
  • Steve_Morgan
Posted April 04, 2001 - 10:31 AM
I used a standard automotive oil filter wrench to hold it, worked perfectly. A steering wheel puller with three #6 screws can be used to take the flywheel off.
P.S. Be careful not to run the screws in too far, they will run into the stator coils...
  • Tim_in_WA
Posted April 04, 2001 - 10:54 AM
Roostn,
Please post your digital pix when you get a chance. I've been thinking of installing a flywheel weight myself.
