Seal saver question wrf 450
9 replies to this topic
  • Youser
Posted March 06, 2010 - 01:47 PM
Hi all, hope someone can help me. I installed one of the long sealsavers on the right side of the bike. It went on ok, but the left side that has the bracket that holds the brake is too big to fit the seal saver around to slide up the fork. I was wondering if there is somehow you can remove the bracket at the bottom of the fork or if I should loosen the triple clams and slide the fork down, install seal saver, then reinstall the fork. I was wondering if anyone else has installed seal savers on their WR 450 or yz and what you have done. Thanks for any replies.
  • chevy power
Posted March 06, 2010 - 02:19 PM
Ive always pulled the forks out of the triple clamp and slid them on from the top. Ive only put them on when installing new seals though. Isnt too bad to slide one fork out especially with another hand.
  • ohioryder
Posted March 08, 2010 - 09:13 AM
Not to hijack the thread but this goes along with the seal savers....I put a set of the velcro seal savers on but the lowwer fork guards have rubbed thru the seal savers. Any suggestions on how to prevent this?
  • OUTERLIMITS
Posted March 08, 2010 - 10:07 AM
Are you still using those little plastic rings that fit in the groove in the fork for the fork guard to slide against? I still use it over the top of the seal saver and have not had a problem, but I don't use the velcro type. Maybe that type is too thick at the point of the velcro to allow using the plastic rings.
  • ohioryder
Posted March 08, 2010 - 01:15 PM
Yes but I left them on the forks and installed the savers over them. And this is where they are being worn away. The velcro area is too thick to install the rings over IMO.
Is there a proper way to install the velcro savers and us the plastic glide rings on top of them?
  • OUTERLIMITS
Posted March 08, 2010 - 03:37 PM
I would imagine you could use one of the big industrial size zip ties as a replacement for the plastic ring and just zip it over the top. If you put the seal saver over the stock plastic ring then, yes it's going to wear through the seal saver every time.
  • Dee Perry
Posted March 08, 2010 - 04:45 PM
What he said!! I used the big heavy duty tie wraps instead of the plastic clamps. Works great.
  • ohioryder
Posted March 08, 2010 - 10:03 PM
Thanks for the suggestions. Sometimes the simplest solutions are overlooked.:banana:
  • CanadianWR450
Posted March 09, 2010 - 02:30 AM
I just took the plastic clamps/rings off completely, and have not had any issues.
  • Youser
Posted March 09, 2010 - 03:06 PM
Thanks for all of the suggestions. I removed the fork which took about 3 minutes, installed the seal saver and put the fork back on. It was really easy. The white plastic rings I put on top of the seal saver and it seems to work pretty good. I saw other people doing in on other posts.:banana:
