shedding pounds
4 replies to this topic
  • bleedblue
Posted May 22, 2003 - 09:22 AM
I have a bunch of motocross races coming up and would like to remove the starter, battery, etc... Any advice on the easiest way to go about it would be great. I have already looked in the wiring bundles when I removed the wires from the clutch and would prefer not to mess with too much wiring if possible. :)
  • John_Lorenz
Posted May 22, 2003 - 09:26 AM
Last Months MXA had an article on converting the WR ionto an MX ready machine.
Might want to get that from them
  • Hick
Posted May 22, 2003 - 12:14 PM
They left the battery and starter on.
  • NOMADAK
Posted May 22, 2003 - 07:46 PM
Once the jetting is dialed, you could loose an easy pound by taking off the kickstarter. In your signature, sounds like you already discarded the kickstand and by going to a regular number plate up front, putting aside the headlight combo for non-mx use, you saved some more weight. Did you remove the odometer as well? After moving to aluminum sprockets (wear like butter with this much HP) and non-O-ring chains, I think things get rather pricey in the loosing weight department. Any other ideas in here, fellas?
  • bayou450
Posted May 23, 2003 - 03:53 AM
If your willing to spend a few coins, Yamaha has their titanium & carbon fiber parts list you could go to. From bolt kits to subframe to guards.
