04 YZ450F cold start
11 replies to this topic
  • mxdirtking
Posted February 27, 2010 - 06:25 PM
I recently bought this bike and it is the worst thing ever to get started in the cold. After about 5-7 kicks with the choke on it will backfire and then after about 3 kicks after the backfire it will start. I need some help on this one. Thank you
  • tek_01
Posted February 28, 2010 - 02:45 PM
You are going to need to check a few things first and also specify what cold means, how cold are we talking?
check what size jets you have in there to get a baseline. if the pilot is way off for your weather/alt than its going to be hard to start.
What helps mine (and alot of others) is to give the throttle 2 or 3 twists before you start kicking but dont touch the throttle after that.
  • mxdirtking
Posted February 28, 2010 - 08:29 PM
Its like about in the 30's. I checked the main jet and its the stock 165 and its got a pipe on it so im going to have to jet it so i don't know if that has anything to do with it and i'll try that 2 or 3 twists if it helps but right now i got it all torn apart and waiting for parts because the water pump went bad in it.
  • tek_01
Posted March 01, 2010 - 01:22 AM
I would think the idle circuit would be more of the problem , main jet doesn't kick in until about half throttle, what size was your pilot?
At a guess i would say it should be about 45-48 for that temp and altitude.
It never gets that cold where i live so im not too sure, but alot of others says they need 3-4 twists in extreme cold weather.
Also are the valve clearances in spec?
  • mxdirtking
Posted March 01, 2010 - 11:13 AM
Im guessing that it has the stock pilot jet in it. When i change the main jet do i have to change the pilot jet too?
  • tek_01
Posted March 01, 2010 - 12:35 PM
Nothing says you have to change them both
  • kain522
Posted March 01, 2010 - 07:17 PM
Cold start on my 04 goes like this- 2 full squirts on the accel pump, full choke, and it will almost always start on the first or second kick. Even after a Wisconsin winter, it will fire in 5-7 kicks. Hope this helps.
  • mxdirtking
Posted March 01, 2010 - 08:40 PM
Nice! Its better info when someone knows the Wisconsin winters!
  • kain522
Posted March 02, 2010 - 10:41 AM
Did it work for you? Where in Wis are you? I'm in Waterford.
  • mxdirtking
Posted March 02, 2010 - 11:30 AM
My bike is all torn apart right now because that water pump went out in it but ill try it as soon as i get it put all back togather. I'm in Richland Center half way between LaCrosse and Madison>
  • kain522
Posted March 02, 2010 - 04:31 PM
Ok, my in laws are in Mineral Point. Maybe I'll see you on the trails this summer.
  • mxdirtking
Posted March 02, 2010 - 07:58 PM
You never know
  • Hot  36 replies
  • Hot  113 replies
  • 9 replies
  • Hot  50 replies
