2010
22 replies to this topic
  • delmas
Posted February 26, 2010 - 06:46 PM
picking up my 2010 saturday mourning.
  • CaptainKnobby
Posted February 26, 2010 - 07:13 PM
All right:banana: Way da go!!!!!:thumbsup:
  • BBrown626
Posted February 26, 2010 - 08:48 PM
I went riding yesterday. First real ride since breaking it in. The most fun I ever had on a bike! I can't wait to race it. It really does handle well and the power is fantastic.
I recommend you ditch the MX helmet and wear a half helmet for the first few rides if you have one. There is no way to fit such a big smile in an MX helmet!
  • motojase316
Posted February 27, 2010 - 05:16 AM
Nice, You will be Super pumped!!!
  • Joe105
Posted February 27, 2010 - 05:30 AM
post some pics ASAP
  • delmas
Posted February 27, 2010 - 01:57 PM
do you use 10 - 40 as recomended or can I use up some 20- 50 I have.
The oil drain bolt is a pain to get to.
I guess I won't be using a torque wrench on that one.
I will get to break it in Sunday.It really shifts smooth.
this is going to be a fun bike .
If anyone near Byron ga. needs a new bike byron Yamaha has a white one not sold yet.
  • CaptainKnobby
Posted February 27, 2010 - 02:10 PM
I use the 10-40 cause it supports the temps I ride in. it wouldnt hurt to use the 20-50 ,it just has a lower and higher temp.
You can use a torque wrench but you will need a small tool and I have two of them. One is a 12mm and the other is a 14mm. all they are is a stubby short wrench about 3 inches long and at one end there is a square notch cut in it.
the notch is for a torque wrench to snap in to it(like a extension to a rachet)
Here are the wrench torque adapters.
http://pitposse.com/potowrad.html
Those stubby wrenchs are for tight spaces where a torque wrench wont fit.
  • BBrown626
Posted February 27, 2010 - 03:33 PM
Motion Pro makes one with a 12 and 14 on a single wrench. You can pick them up at a lot of on-line stores. They are most often used for 2-stroke cylinder nuts since they are back in areas you can't get the head of a torque wrench.
  • delmas
Posted February 27, 2010 - 05:26 PM
thanks
Posted February 27, 2010 - 08:41 PM
20w-50 does not have a lower temperature range than 10w-40. Quite the opposite in fact. 10w-40 is good down to 14 ℉, whereas 20w-50 is not recommended below 40 ℉. Likewise at the high end, 40wt is adequate up to 114 ℉, while 50wt protects up to 125 ℉ or so. In Florida, 20w-50 is probably OK year round, as it would be here. I use 10w-40 October through June, however, as I prefer a lighter oil for it's more rapid circulation, and it really is also adequate for any temperature I'm apt to ride in. The heavier oil in the hotter months I think adds a little more protection for the transmission and the main bearings, so I use it July-September.
When using torque adapters, be sure to attach them at right angles to the torque wrench so that the wrench reads accurately.
  • Scrubba
Posted February 27, 2010 - 10:13 PM
who needs a tork wrench for a oil drain plug?
  • delmas
Posted February 28, 2010 - 05:32 AM
thank for the tips I wondered about the adapter
  • Solid State
Posted March 01, 2010 - 04:14 PM
Apparently some folks do!
  • ktm200xc 457racer
Posted March 01, 2010 - 04:19 PM
people who dont want to strip the threads in there CASE!!!!:thumbsup:
  • ZéPovinho
Posted March 01, 2010 - 04:21 PM
Just all the guys who have stripped them...
Posted March 01, 2010 - 05:47 PM
I don't know of a good way to say this, but I never use one for stuff like that. Mine don't fall out, and mine don't strip. :thumbsup:
It's something you learn.
  • delmas
Posted March 01, 2010 - 05:57 PM
If you have any experince at all in mechanics you won't strip it.
If you can put a torque wrench on it why not.it can't hurt.
  • delmas
Posted March 01, 2010 - 06:00 PM
do you use a torgue wrench on you triple clamp pinch bolts?
  • norcal_hoss
Posted March 01, 2010 - 06:03 PM
I do always , same with linkage. But not on a drain plug .
  • delmas
Posted March 01, 2010 - 06:06 PM
i always use it on pinch bolts.
  • 9 replies
  • Hot  36 replies
