yz450f 2009 sprocket interchangeability with honda suzuki or kawasaki
12 replies to this topic
  • yz450fcranker
Posted February 24, 2010 - 06:27 AM
Does any sprocket from suzuki or honda fit on a yz450f 2009 because we dont have any other choice here
  • aedwards07
Posted February 24, 2010 - 07:14 AM
The front is the same as a kx250f/kx450f according to my ironman sprocket label.
Posted February 24, 2010 - 07:19 AM
Rear sprockets? No.
  • l_campionero
Posted February 24, 2010 - 05:29 PM
How do you not have a choice? Do the United States Postal Service or UPS deliver to you?
The Thumper Talk store has a variety of choices of sprockets, and you get a discount for being a member.
http://shop.thumpertalk.com/
  • osheen
Posted February 24, 2010 - 08:51 PM
Sprockets are one thing that I don't understand why the bike manufacturers haven't standardized. There is no reason that they shouldn't all be the same. Back in 99, I believe, when Yamaha re-designed their hub would have been a perfect opportunity to adopt Honda's inner diameter and bolt circle.:ride: But hell no, it's dang close but so far away! It's not like this is a performance part. If you took all the brands' sprockets and laid them on top of each other, you'd see that there is just enough difference to piss you off that they don't fit each other.
As you look at some parts that ARE sometimes interchangeable between brands - Tires, spokes, spark plugs, pistons, rings, rods, bearings, seals, clutch plates, levers, brake parts, throttles, suspension parts, chains and front sprockets but NEVER rear sprockets. :thumbsup:
Sorry, this doesn't help the OP but I just had to vent! If a guy has access to shop eqipment it is possible to make sprockets fit.....
Edited by osheen, February 24, 2010 - 08:55 PM.
grammar
  • FinchFan194
Posted February 24, 2010 - 09:14 PM
Pistons though? I think not. . .
Posted February 24, 2010 - 09:23 PM
Back in 99, I believe, when Yamaha re-designed their hub would have been a perfect opportunity to adopt Honda's inner diameter and bolt circle.:ride: But hell no, .....
Knowing Honda, they have a patent on sprockets with a mounting circle that size. :thumbsup:
  • mx369
Posted February 25, 2010 - 10:55 AM
kawas will bolt to a YZ hub. BUT the center (big hole) is just 2mm larger than Yamahas. Dont do it. Sprocket need that lip to help support it. Friend did it and learned a lesson!
  • usp4u
Posted February 25, 2010 - 11:02 AM
There are several, 2 strokes in particular.
  • aedwards07
Posted February 26, 2010 - 01:01 PM
yz250 and rm250 come to mind.Especially since the rm250 motor is basically a yz250 copy.
  • FinchFan194
Posted February 26, 2010 - 02:36 PM
Ya but I figured we were talking 4 strokes since this is the YZf forum. I guess that is what I meant about interchangeability.
  • pscook
Posted February 26, 2010 - 07:56 PM
Apparently, Sunstar believes that the 2009 has a wide and varied selection to choose from-
Make CC Model Years Ratio Chain Size
YAMAHA 125 YZ125 1999-01 3.69 520-112
YAMAHA 125 YZ125 2002-04 3.77 520-112
YAMAHA 125 YZ125 2005-08 3.69 520-112
YAMAHA 125 YZ125 2009-10 3.69 520-114
HONDA 200 XR200R 1984 3.85 520-108
HONDA 200 XR200R 1985 3.85 520-108
HONDA 200 XR200R 1986-03 3.62 520-108
YAMAHA 230 TTR230 2005-09 3.77 520-106
YAMAHA 250 WR250F 2001-06 4.00 520-114
YAMAHA 250 WR250F 2007-09 3.85 520-114
YAMAHA 250 WR250R 2008-10 3.31 520-108
YAMAHA 250 WR250X 2008-10 3.23 520-108
YAMAHA 250 YZ250F 2001-06 3.69 520-112
YAMAHA 250 YZ250F 2007-08 3.77 520-112
YAMAHA 250 YZ250F 2009-10 3.77 520-114
HONDA 250 XR250R 1984-85 3.85 520-108
HONDA 250 XR250R 1986-87 3.69 520-108
HONDA 250 XR250R 1988-89 3.69 520-108
HONDA 350 XL350R 1984-85 2.86 520-102
HONDA 350 XR350R 1983-84 3.00 520-104
HONDA 350 XR350R 1985 3.00 520-106
YAMAHA 400 WR400F 1999-00 3.57 520-114
YAMAHA 400 YZ400F 1999 3.50 520-114
YAMAHA 426 WR426F 2001-02 3.57 520-114
YAMAHA 426 YZ426F 1999-02 3.50 520-114
YAMAHA 450 WR450F 2003-06 3.57 520-114
YAMAHA 450 WR450F 2007-09 3.85 520-114
YAMAHA 450 YZ450F 2003-04 3.43 520-114
YAMAHA 450 YZ450F 2005 3.64 520-114
YAMAHA 450 YZ450F 2006-09 3.77 520-114
YAMAHA 450 YZ450F 2010 3.69 520-114
HONDA 500 XR500R 1983-84 3.43 520-104
HONDA 600 XR600R 1985-87 3.43 520-110
I know that the early XR sprockets fit, that's how I got such a big selection of sprockets for my YZ.
Amazing what the internet holds these days...
  • Brawg
Posted February 26, 2010 - 08:27 PM
You are right! I think we will see this one day. Look at every industry. At one piont, chevy, ford, honda, yamaha, every one made their own stuff. Now, with the modern manufacturing era and the ability to outsource things to japan, china, etc and make it efficient we have digressed to components. For example, navistar makes ford diesels, Kayaba makes forks for Yamaha, and energizer and duracell are made in the same factory! Likewise, wheels themselves used to be honda, yam, kaw, etc. now, excel or DID makes the rims....all it will take is for these manufactureres to be "acquired" by a profiteering mogul and streamline the mfg process by removing the various "models" or different size hub options and badabing, standard size hubs...
U are welcome....
