new to the wr world
8 replies to this topic
  • T-Doshi9
Posted February 23, 2010 - 08:54 AM
i just got a 98 wr400. it has the bbk on it and several upgrades. i have 3 questions.
1. the stupid decomp lever is TINY. i rode a buddy's 426 and the lever was useable and you could move it. any ideas on this?
2. should i just get the wr450 exhaust cam and don't worry about question 1?
3. do they make a rekluse that works for these?
  • 123BigcoopDawg576
Posted February 23, 2010 - 09:28 AM
Yes, get either the YZ or WR 450 03-05 Exhaust Cam :thumbsup:
  • Butta
Posted February 23, 2010 - 02:24 PM
I recommend the Hot Cams auto-decomp equipped cam for your model. The 450 cam chains are a bit different (and therefore the cam gear teeth are different) and don't match up "perfectly" to your model. It will work, but it's not ideal. The Hot Cams will be a perfect match.....
  • ASternad
Posted February 23, 2010 - 06:40 PM
Doesn't look like it. Call em to be sure.
Otherwise you can talk with Rev-Loc or EFM.
  • wondermuscle
Posted February 24, 2010 - 02:56 PM
Unless you port the head, don't get the hotcams intake cam. Not worth the $$. The exhaust cam does just fine.
  • Butta
Posted February 24, 2010 - 07:45 PM
Good call!! The exhaust cam is the only one you need for the easy start mod....
  • T-Doshi9
Posted February 25, 2010 - 08:49 AM
ok.. i was reading around and kinda thought this was what i needed to do. but wanted to ask for sure. thanks guys. i think i will try to find an exhaust cam now. one more question... i have read some places that if i go with the yz cam that the timming is diff. is that the only diff? performance diff?
  • T-Doshi9
Posted February 25, 2010 - 08:50 AM
i know they don't have them on the site. but as with my kx250 same thing but you could use the 250f and shorten the shaft just a bit and it works. anyone use anything like that?
  • redhurricane
Posted February 25, 2010 - 09:26 AM
About time you defected....
Save the money on the cam, learn the routine on starting. Just my humble opinion.
