wiring questions
4 replies to this topic
  • ZX10Rsilver
Posted February 22, 2010 - 11:58 AM
Ive just bought a Yamaha yz426f it already has the sator kit on it but not sure what previous guy has done but there are a few wires that have been pulled out ill post pics soon just wondering if any one could tell me what they are for. Also how easy is it to fit a battery a 12v one and were could it go?
  • Birdy426
Posted February 22, 2010 - 12:21 PM
What stator kit? WR stator? Ricky Stator? Electrolux? Let us know. If it's a WR stator, at least the pink wire shouldbe capped and stowed...
  • Birdy426
Posted February 22, 2010 - 12:22 PM
Small battery fits in the air box (see Baja Designs...)
  • ZX10Rsilver
Posted February 24, 2010 - 08:22 AM
Not sure which make it is but has coloured tape at the end of every connection
  • Polar_Bus
Posted February 24, 2010 - 04:49 PM
Most dirtbike conversions use a simple AC lighting coil. You probably have 3 wires exiting your stator, and there should be an additional yellow single wire (aux. lighting coil) exiting the stator housing that feeds the 12V AC power to run a headlight. You should also have a voltage regulator bolted somewhere on your frame.
Here is a link to my detailed method as to how I converted my KX500 over to 12V AC power. :
http://www.kxriders....pic,6603.0.html
If you want the system to work utilizing a battery, now you have to have a 12V DC type system. This requires a voltage regulator/rectifier, and slightly different wiring.
  • Hot  113 replies
  • 10 replies
  • Hot  47 replies
