yz400f exhaust fitment, what other years?
6 replies to this topic
  • tek_01
Posted February 21, 2010 - 11:41 PM
My brother looped out doing a wheelie on the weekend and crushed his yoshi pipe beyond repair. Im assuming the 426 exhausts fit but what about the first gen 450s? just the silencer is needed and i have my stock one here for the time being
any help appreciated
thanks
Posted February 22, 2010 - 08:26 AM
450 pipes are iffy. Some will, some won't. Stock ones generally won't. Aftermarket pipes made as the FMF products are, with a slip-on band for a muffler hanger and a separate mid pipe, are more flexible as to fit, and are more likely to be usable.
  • garrettstump
Posted February 26, 2010 - 09:19 AM
so is what your saying gray is that basically the 450's exhaust will fit my 426 header but the exhaust mount will have to be movable or modified unless has a slide bracket.
Posted February 26, 2010 - 09:44 AM
Sometimes. Sometimes they fit. The mid pipe mounting hole and the rear hanger misalign by small amounts each. Sometimes you can do some minor filing or tweaking, sometimes it seems impractical. Case by case.
  • c_dasilva127
Posted February 26, 2010 - 01:25 PM
i bought a ti powercore for an 03-05 450 for my '00 426. the holes dont match up but the spacing is very small. i just bolted it at the sub frame and the bracket on the muffler is about half an inch lower than the mounting hole so i just made a bracket and drilled two holes in it, one for the bracket one the can, and one for the subframe and it mounted right up.
Edited by c_dasilva127, February 26, 2010 - 01:45 PM.
  • yz454
Posted February 26, 2010 - 09:01 PM
Go with the 426 pipe.The pipe volume works well on the 400.
  • buzzgrizz
Posted February 26, 2010 - 10:39 PM
I was wandering how you go that newer style fmf to fit.
