426 wierd starting problem
18 replies to this topic
  • usaf_yz426
Posted February 21, 2010 - 01:57 PM
i am having some weird issue's starting my 426. It will not start unless i have the hot start and choke levers pulled at the same time. but once it starts i can push the hot start lever back in and it will idle with the choke on. but once i push the choke back in after it is warmed up, it dies. it seems weird i would have to pull both levers out to start it. any idea's.
  • Lota Fun R
Posted February 22, 2010 - 12:56 AM
Yes, your jets are plugged. Both fuel and air. Take it all apart and blow air through it, re assemble making sure all passages are clear.
  • usaf_taco
Posted February 22, 2010 - 08:49 AM
i will give that a try, i took the bowl off and there was no tarnish in there. so i assumed the jets were good to go.
  • JandJ07
Posted March 01, 2010 - 07:15 PM
Hey I know this post is a few days old...have you got it fixed yet. I have seen a condition similar to yours when the A/F adjust screw in the bottom of the carb had vibrated all the way out. Just an idea to check.
  • usaf_taco
Posted March 02, 2010 - 11:39 AM
the little orifices on the side of the pilot jet were a little clogged up. i'll let you know when i get her back together tonight.
  • usaf_yz426
Posted March 06, 2010 - 04:47 PM
well, i thuroughly cleaned the carb. and checked my valve clearance. and i still have to pull the hot start and choke to get it started, then once its started ill turn off the hot start and it will idle with the choke on. but once i turn the choke off, it dies. i am wondering if jetting is the issue now. but it was running perfect 5 months ago.i am at my witts end.
  • flapwick
Posted March 06, 2010 - 09:29 PM
Do you still have the decompression lever on it? I wonder if the cable is too tight and it may be opening slightly.Just a shot in the dark.(I'm the king of shots in the dark.Mostly because I have no actual knowledge,although I have been told that I have the brain of a mighty T-REX!)
  • usaf_yz426
Posted March 07, 2010 - 12:18 AM
negatron, i have the hotcams with the autodecomp loab. and yes the timing is spot on. and for good measure, i changed the spark plug. i have a 45 pilot jet. but whats got me frazzled is why it starts with the hot start and choke on. don't they kinda contradict eachother?
  • usaf_taco
Posted March 16, 2010 - 11:15 AM
well i have verified that my valves aren't stretched. i am coming to a conclusion that the problem is jetting, but i haven't messed with the jets at all.
  • usaf_taco
Posted March 17, 2010 - 10:14 AM
it's just an idea, but i am sure my bike's muffler is long overdue for repacking. do you think this can cause it to lean out and run like crap?
  • usaf_taco
Posted March 18, 2010 - 10:16 AM
any idea's, i am at a loss. i could use some intelligent input.
  • gscx
Posted March 18, 2010 - 10:20 AM
I dont think your muffler has anthing to do with it, but if it needs it then it should be done. Did you just clean the jet? The pilot circuit could be clogged too. Take out your fuel screw and spay from the throat of the carb down. You will see the little hole in the intake side of the slide. You should probly take your carb off to do this. And take out the pilot jet too when you do it
Posted March 18, 2010 - 11:00 AM
"Idles with the choke on, won't idle with it off"
That's a pilot circuit problem, plain and simple.
  • Obstructed jets or passageways, including the discharge port
  • Pilot screw too tight/not adjusted properly
  • Pilot screw O-ring missing or damgaged
  • Pilot screw missing
  • Throttle slide vacuum plate damaged or installed upside down
  • Ryan426
Posted March 18, 2010 - 03:21 PM
I've been very, very happy with my 426. Been firing up on the 1st kick this last week.
  • gscx
Posted March 18, 2010 - 04:24 PM
I dont really understand how that helped any
  • usaf_taco
Posted March 19, 2010 - 06:27 AM
i cleaned the carb thuroughly. the o-ring, spring and washer are on the fuel screw. the throttle plate is in serviceble condition and is installed correctly. and the fuel screw is in the same exact position it was in when it last ran correctly.
but my question is, how come it only starts when i have the hot start and the choke levers pulled. it will not start on the choke, but it will idle "ok".
Posted March 19, 2010 - 08:34 AM
With the pilot circuit not functioning, there is no fuel delivery without the "choke" (not truly a choke) on. The is also no air blended with the fuel as there is in the functional pilot circuit, so the hot start (or cracking the throttle partially) is necessary.
Be certain you inspect the air jets in the mouth of the carb.
  • usaf_yz426
Posted March 19, 2010 - 03:40 PM
well, i got it to run. i didn't have my idle adj. screw out enough. now it starts right up, and idle's without the choke on. so i took it for a spin, wow i forgot how much power this thing has. makes my drz-sm feel like a mo-ped.
p.s. i double checked my pilot circut works,i almost got sprayed in the face by being complacent.
  • Ryan426
Posted March 19, 2010 - 06:36 PM
Good to hear.:thumbsup: Now get out there and tear some sh!t up...:lol:
  • Hot  47 replies
  • 0 replies
  • 10 replies
