vent hose routing after install sub mount damper?
4 replies to this topic
  • HunterGSXR
Posted February 20, 2010 - 03:30 PM
Where are you guys routing your hoses? I haven't found a good place since putting on my Scotts damper :ride:
  • l_campionero
Posted February 20, 2010 - 03:54 PM
What hose? The gas cap hose? Stuff it between the tank and the frame, or between the clutch cable and the frame. Doesn't really matter, as long as it's not flopping around.
  • JWW
Posted February 20, 2010 - 07:50 PM
I stick mine through a bracket on the left side.
Edited by JWW, February 20, 2010 - 10:52 PM.
  • waterman7474
Posted February 22, 2010 - 09:15 PM
get a little stubbie vent hose
  • RR@ARS
Posted February 23, 2010 - 07:38 AM
I tried 3 dirrefent brands of those stubbie vent caps and none of them worked for me. They all did not vent properly and ended up causing my bike to stall after about 30 seconds. I even pulled the one off my other bike that I knew was not defective and it still did not work on the wr450.
I use a longer hose and route it under the sub mounted damper
