move parts from '07 YZ250 to 08/09 YZ450F ?
20 replies to this topic
  • shrubitup
Posted February 18, 2010 - 10:25 AM
Shhhhh! Don't tell no one. I am still secretly lusting for no spooge or smoke and some more torque too. I also think compression braking is cool. :ride:
However! My YZ250 is so cherry with aftermarket parts, re-valved/re-sprung suspension, and a number of woods focused mods. Some will be moved over and others prolly re-purchased. :ride:
In order for this to be a go I would like to directly bolt on my suspension and upper triple clamp if possible. I have a 2007 YZ250 smoker and am considering the '08 or '09 YZ450F. I will act very slowly on this but just want the information to ponder. :lol: I would move the 450F parts over to the 250 and then sell it.
The '08+ YZ450F is the version where the OEM quiet shorty silencer was installed, right?
  • cowboyona426
Posted February 18, 2010 - 10:39 AM
Ohhh you are in big trouble :ride: As far as I know, everything should swap over just fine as far as the suspension. You may have to swap the steering stems out though.
I can't recall if the start of the OEM shorty muffler was 07 or 08, but I want to say 07.
Posted February 18, 2010 - 10:50 AM
To begin with, the stock spring rates are considerably different because of the difference in weight. The 250 comes with .43/4.9 springs, whereas an '08 450 has .47/5.5's. So the spring rates will be wrong regardless. If you've had any valving work done, that will likely not work the same on the 450, either, even if the spring rates are corrected. All in all, I'd say you're better off starting over.
Another matter is that the '08 450 has a smaller brake caliper, and a master cylinder to match, and all of that would also need to follow from one bike to the other.
Top clamps are not interchangeable that I know of, either.
The front wheels do interchange, though, as do the rears with an '08 450. The '09 has a larger rear axle.
  • shrubitup
Posted February 18, 2010 - 10:59 AM
Thanks Grayracer!
I have big ass springs in there now to accommodate my weight but alas they are calc'd for the 250 bike weight so :ride: I will take up the matter with LT Racing who did my 250.
Is it safe to say that it could be switched over however? I've got about 100 hours on the 250 suspension so maybe it just makes sense to start over. :ride:
Posted February 18, 2010 - 11:25 AM
Basically, the major components will switch. The shock will, and the forks will fit in either triple clamp set. I'm not certain as to whether the clamps will fit as a set, or if the tops can be interchanged.
Then there is the matter of the front braking system.
IMO, you should not plan on doing the swap. I don't see that there is any advantage to it, beyond possibly the triple clamp.
  • shrubitup
Posted February 18, 2010 - 11:30 AM
Which is a negligible cost really and may not even be needed. I like the Pro Taper Accutrax on this 250 because the ergos are cramped without it. The 450 ergos could be larger which would negate the need for the aftermarket clamp. :ride:
Posted February 18, 2010 - 11:58 AM
Something else that very nicely opens up the YZ450 is a set of Windham bent Pro Taper bars. Moves the hands up and forward. :ride:
  • cowboyona426
Posted February 18, 2010 - 12:30 PM
A big x2 to that one, love the Windham bend bars on my 06.
  • ThumperKid250F
Posted February 18, 2010 - 02:17 PM
me too love they way they feel..
  • FinchFan194
Posted February 18, 2010 - 03:39 PM
The shorty muffler started in 08.
Posted February 18, 2010 - 03:45 PM
The shorty muffler is also a piece of crap.
To be blunt. :ride:
  • shrubitup
Posted February 18, 2010 - 03:56 PM
To be blunt. :ride:
Have read it's quiet but saps power. I like to turn YZs into trail bikes so it may be OK for what I need if I just add a PMB sparky. Seems the FMF Q4 is only $100 more so I dunno. :ride:
Posted February 18, 2010 - 04:02 PM
It might. But the annoying thing about the pipe is not that it cuts peak power; it does hurt it much. The problem is that it puts a huge dip in the curve at right around 5000 rpm, which is right in the meat of your low/mid range grunt. Very disappointing.
  • Luv2crash
Posted February 19, 2010 - 11:37 AM
Shrub i won't tell the others, because i too am interested in a 450...
  • shrubitup
Posted February 19, 2010 - 11:46 AM
It's gets old people telling me that I'm not riding it hard enough, it's jetted poorly, it has a blown crank seal, I'm using the wrong pre-mix oil/ratio, my 10 hour top end wasn't broke in properly, etc. etc. Too much smoke and spooge to ride tight wooded trails. The motor was designed to run fast on a MX track - sorta hard to correct that for optimal combustion efficiency at slow speeds. Aside from that, great bike but I'm sick of the smoke and spooge. Maybe a KTM XC but I'm too cheap for that AND I've never had a 450F so why not!
The B.S. about the 450F inertia and not wanting to turn - I guess I hafta find out for myself eventually. :ride:
  • Luv2crash
Posted February 19, 2010 - 11:48 AM
Also 450's seam to be heading forward in time
  • cowboyona426
Posted February 22, 2010 - 08:44 AM
shrubitup, if you want to take one for a spin some time you are welcome to come thread some trees with my 06.
  • ThumperKid250F
Posted February 22, 2010 - 10:11 AM
idk if anybody said this but you cant switch over the linkage from the 2 smoker to the 450.. the linkage is longer for the 450.. but you can switch the shock over
  • shrubitup
Posted February 24, 2010 - 10:01 AM
Naw, don't want no linkage just the shock perhaps.
Cowboy, I'll have to get over there this spring and do that! :thumbsup:
  • cowboyona426
Posted February 24, 2010 - 03:03 PM
Sounds like a plan to me! Just don't make me spend too much time on the ring-ding :ride:
  • On January 15, 2017
  • 5 replies
  • Hot  47 replies
  • Hot  38 replies
