Whats it worth?
20 replies to this topic
  • 92FiveOGt
Posted February 15, 2010 - 09:58 PM
I'm new to the site guys, and looking into trading my quad for a bike.
here's the specs...
08 yamaha yz450f
1 1/8 renthal bars
full yoshimura exhaust
aftermarket black wheels
carbon fiber frame guards
wave brake rotor on the rear
cv4 hoses
break away ASV levers with hotstart
R&D Carb bowl
Boysen holeshot device
MX tech front fork setup ($2800)
Pro Action rear suspension
suspension is set up for a 180lb rider
Thanks a lot in advance guys, hope to be joining you soon!
  • TheHarp
Posted February 15, 2010 - 10:39 PM
I'd say a stock 08 in good condition with reasonable hours on it is worth about $4000. How much are all the extras on this bike worth to you? How fresh is the motor?
  • dvn
Posted February 16, 2010 - 04:02 AM
I don't think so. You can buy a new 09 for 4899.00 and I've seen new 08's for 3899.00
  • TheHarp
Posted February 16, 2010 - 07:13 AM
Didn't know they were going for that little. I would guess that new 08's are not that easy to find.
Posted February 16, 2010 - 09:27 AM
Low hour '08's are not hard to find, though, and you can get fairly good ones for between $3000-$3500 these days. The bike listed would appear to have been a race bike, as opposed to something that was mostly used recreationally. Consider the overall condition carefully. The extra stuff adds very little to the true value of the bike except in the case that it makes it what you want it to be.
In the end, if both of you are happy with the trade, do it.
  • 92FiveOGt
Posted February 16, 2010 - 10:46 AM
What is important to watch for on these bikes? I've read a lot about listening for any knocking... anything else I should pay attention to when looking/riding it?
Posted February 16, 2010 - 11:54 AM
If you're going to reject a YZ450 for engine noises, you'll never buy one. They make more noise than a pipefitting school when they're healthy. The thing is to be familiar with the normal noise levels. Listen to a few of them before you choose, or have someone who knows the breed check it out.
Otherwise, there isn't a lot of out of the ordinary faults. Do inspect the steering head area for cracks (more of an issue on the '07's than others). Also look under the chain slider on top of the swing arm for serious scuffing wear. (See: http://members.cox.n...r/wearplate.htm )
Another spot often overlooked is the chain slider at the front underside of the swing arm pivot (7:00 o'clock to the pivot, viewed from the left side). Check for a hole worn in the slider at that point, and if found, see if the swing arm is badly worn.
The head bearings are subject to water intrusion. Put the bike on the stand and see if the steering rotates smoothly or not.
Otherwise, it's all standard stuff.
  • KJ790
Posted February 16, 2010 - 12:49 PM
On top of what Gray said, pull the seat and the air filter off and look for any signs of dust in the intake. Not too long ago I went to look at a bike that looked pretty good for the most part. Pulled the air filter off and there was dust all down inside the intake, big time deal breaker for me right there.
  • ThumperKid250F
Posted February 16, 2010 - 01:19 PM
agreed.
  • 92FiveOGt
Posted February 16, 2010 - 03:49 PM
Found out it has 130 hours on it. So would I need to do a top end rebuild to be safe?
Posted February 16, 2010 - 03:55 PM
130 of what kind of hours?
  • Mike546
Posted February 16, 2010 - 04:39 PM
130 is a lot of hours for any bike. Aside from the motor all the bushings and bearings in the chassis may need attention. What is your quad worth?
  • 92FiveOGt
Posted February 16, 2010 - 05:08 PM
I'll assume the worst and say mostly racing. Its on its 2nd owner, he hasn't touched the engine.
I had what was done and what my quad was worth... but it got deleted by the powers above...
Its worth $5500, built big bore engine, elka shocks all around, long travel a arms plus a ton more.
Its in awesome shape and I hate to trade into something that needs a ton of attention.
  • Mike546
Posted February 16, 2010 - 07:17 PM
If it's truly worth $5500 you could easily sell it quick for $4000 or more and get a bike with a lot less hours on it.
Posted February 16, 2010 - 07:20 PM
If in fact your quad is worth that much in the current market, it's not a fair trade. An '08 that's been mostly raced for that long without engine work, even if very well maintained otherwise, is absolutely never going to be worth $5500 when a brand new '09 can be had for that. As said earlier, clean, low hour '08's are currently worth about $3200.
  • usp4u
Posted February 17, 2010 - 09:01 AM
OP, I just got done doing this type of trade myself. It's tough to sell a race quad right now in general. It's impossible to sell for a decent price and not take a bath on it. There is a site I fequent that has ALOT these trades going on, PM me and I'll send you a link.
FWIW, I traded an Original full Walsh YZ hybrid with EVERYTHING (long travel PEP's, TC motor, Walsh swinger,arms, stem), a National level for a 2 hr. bonestock '08 yz450. $7500 quad that would take $15000 to build traded for a $3500 bike b/c noone has money to buy race quads right now. Quad was up for sale for 8 months, best offer recieved $4000.
If both parties are getting what they want, then do it. Dirt riding is an expensive hobby. :ride:
  • MATTH530
Posted February 17, 2010 - 03:43 PM
Hey look alittle closer... Gray I cant belive you missed this.. The bike in the photo is not an 08! If I were to bet, I would say it is an 06. No wave roter in front and the side cover case's and valve cover are not black... So what is an 06 worth and how many hours are on it..
Matt
Posted February 17, 2010 - 04:16 PM
You don't have enough evidence to make that statement. The paint is clearly rubbed off the clutch cover, and the picture isn't good enough to determine whether it's black or dark gray. There's no wave rotor in front, but there is in the rear, so which wheel came with the bike?
The VIN number will always determine the year model anyway, but it's a good idea when buying anything used from an unknown source to be fairly certain of what you're getting.
Interesting, though.
  • husqy360
Posted February 17, 2010 - 04:20 PM
i whouldnt trade a machine in great shape for 1 that is not even close, 130 is lots for racing.
a stock machine will last longer, especially when it wasnt raced hard.
2800 bucks in suspension :ride: unless ur very very good a $250 fork job should be more then enough.
2 owner, go figure if this bike was properly maintaine, and how hard it was actully raced, beacuse it was !
stock yzfs are good enough for most of humans.!
no
  • 92FiveOGt
Posted February 17, 2010 - 10:08 PM
Vin jyacj10c38a0*****
  • 5 replies
  • Hot  50 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • On January 15, 2017
  • Hot  113 replies
