Reusable oil filters?
5 replies to this topic
  • Jason
Posted December 01, 2000 - 03:07 PM
I heard someone mention a reusable oil filter here. Where you'd get it? I looked in chaparral and asked at my yamaha shop, they've never heard of them.
Or maybe I just misunderstood, do yall reuse the regular paper filters? This seems rather risky to me.
Thanks,
Jason
  • Boit
Posted December 01, 2000 - 03:37 PM
Scott's Performance in Montrose California handles the permanent oil filters. These are claimed to be of a finer micron than stock and are made of stainless steel mesh. This is the same Scott's that makes the steering dampner.
  • holeshot
Posted December 01, 2000 - 03:44 PM
The stock brass screen filter in the YZF can be cleaned and re-used many times. Many are still using the original filter in their '98 YZF's.
  • MikeOK
Posted December 01, 2000 - 05:45 PM
I've found I can get about 4 or 5 oil changes out of the stock type filters before the cheezy rubber seals start to get compressed. I use mineral spirits to clean it then use a rag to get the little flecks out of it.
Mike
  • Tony_Williams
Posted December 02, 2000 - 11:45 PM
I've re-used my oil screen dozens of times. The screen at the bottom of the oil resevoir has never been contaminated.
Tony Williams
YZ400F (98)
  • Guest_Guest_*
Posted December 04, 2000 - 06:14 AM
I reuse my metal mess oil filters also with no problems. I clean it with a spray can of brake parts cleaner, works great. Most of you probably already know this if you own a 2 smoke, brake parts cleaner works great for cleaning fouled spark plugs also. Spray it on, let it drip dry, and in just a few seconds you have a clean/dry plug. A new plug is always best but a clean spare plug sometimes comes in handy.
Paul in AZ
  • Hot  47 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • 10 replies
  • Hot  50 replies
