Chain puller bolt problem
4 replies to this topic
  • kevin1209
Posted February 11, 2010 - 05:02 PM
I also posted this in the YZ forum, but the WR bikes are the same so hopefully someone here can help me. I just bought a 99 YZ400, and the previous owner had just installed new front and rear sprockets. However, the chain was really loose. Today when I tried to tighten the bolts at the chain pullers, the bolts will only turn 1/8 either way (both of them do the same thing). Then they feel like they are going to snap if I push any further. I have loosened the "lock" nut that's against the rear arm, and I loosened the axle nut. My friend's bike (98 WR400) is parked next to mine, so I loosened his the same way and they turn very easily. I do not want to break these bolts off and have to deal with that. Any suggestions? Has anyone ever heard of this happening? It's like they are seized up in the hole or something.
  • kalvin22
Posted February 11, 2010 - 05:07 PM
those are famous for locking up on all bikes. if you have any movement at all that is a good thing. I would start by soaking them with a good penatrating oil and carefully try working them out. if they break its not the end of the world it just means alot more work. if you get them out in one piece make sure to put anti-seize on before re installing.:ride:
  • Birdy426
Posted February 11, 2010 - 10:08 PM
PB Blaster is the solvent of choice!
  • BAHeron
Posted February 12, 2010 - 08:35 AM
The threads on the swing arm may be slightly stripped. You might want to run a tap thru it before putting it back together.
  • motodiver13
Posted February 12, 2010 - 09:26 AM
I love pb blaster!!!
