Help.....is my WR 400F YZ Timed?
3 replies to this topic
  • ScottJ
Posted May 16, 2003 - 06:20 PM
I purchased a used 2000 WR 400F from a motorcycle shop in San Diego. The previous owner seems to have done all of the normal modifications to gain power. However, I don't know if he changed the timing. How can I determine if the previous owner changed to YZ?
Thanks.....
-Scot
  • Indy_WR450
Posted May 17, 2003 - 04:30 AM
Next time you check your valve clearances (download a manual from this forum if you did not get one with your used bike) look at the timing chain sprockets and count the number of links between the marks on the sprockets. 12 links is WR timing. 13 links is YZ timing. To get to YZ timing from WR you need to rotate the exhaust cam & sprocket only. Leave the Intake cam and sprocket in the factory position. :)
  • XC800.X
Posted May 18, 2003 - 11:29 AM
You have that backwards. 12 is YZ,13 is WR
Shawn
  • blue_beast_wins
Posted May 18, 2003 - 07:55 PM
Shawn
And just to add to that, i beleive it is pins not links. :)
