Dripping fuel
2 replies to this topic
  • Jakes123
Posted February 09, 2010 - 09:08 PM
Hi guys. I have a '99 WRF. When I open the fuel tap, immediately fuel starts to drip from tap and underneath from one of the plastic pipes hanging below. It never stops while the bike has not been started. When I turn the fuel tap off, it still gives about 2 drops every 10 seconds. Is this normal? Any advice will be much appreciated.
  • Birdy426
Posted February 09, 2010 - 10:47 PM
Nope...not normal. Float needle is either worn or stuck, or the o-ring that seals the float needle seat to the carb body is worn. Time to pull the float bowl off and check it out...
  • Jakes123
Posted February 10, 2010 - 02:57 AM
Thank you very much.
