WD40 Spray on Engine
27 replies to this topic
  • 50IsTheNew25
Posted February 09, 2010 - 03:17 PM
Is it advisable to spray your engine down with WD40 after cleaning? It certainly looks better with the slight wet look vs. dried.
How much is too much?
Edited by 50IsTheNew25, February 09, 2010 - 04:00 PM.
  • wchase
Posted February 09, 2010 - 04:34 PM
Wont hurt a thing, I do it when I wash my bike. Dont hit the brakes/rotors with it though.
  • williamsb27
Posted February 09, 2010 - 05:23 PM
Use brake cleaner, wash it off and then use WD-40.
  • Eddie8v
Posted February 09, 2010 - 05:47 PM
WD-40 can act as a corrosive on certain metals when subjected to high temperatures. Be careful!
  • greco3x
Posted February 09, 2010 - 05:53 PM
yeah wd is an oil, and if its not washed off correctly will actually attract and hold onto dirt and stain your metal. before i wash my bike i grab a bottle of simple green and spray the WHOLE thing down, then let it soak all in. i try my best to get the hubs as good as i can, the crankcase and the pieces of the engine between the frame where a rag cant get. let it soak in and hit it with a hose. or pressure washer if you would like. it makes it looks brand new! and is not oil based. actually a degreaser. ride on
  • chayes627
Posted February 10, 2010 - 12:18 PM
+1 on the simple green. works wonders. i only had about 4-5 rides on my bike and had washed it after every ride. thought it looked damn good still, then i used some simple green and was amazed at how much better it looked. also seems to put down a little barrier cause water will bead up after you rinse it off. i also get a gallon of the consentrate from home depot for $10 and a spray bottle and mix my own. year later and i still have 3/4 of a gallon left.
  • wchase
Posted February 10, 2010 - 12:22 PM
Yes, Simple Green is awesome, I wash my bike down with it every time I am done riding. Spray it off and then spray wd40 on the engine, exhaust and swing arm...bike still looks like it did the day I bought it.
...Dont use that purple power...It works better that simple green but will stain the aluminum! I used it on my old RMZ and it was a bad scene.
  • greco3x
Posted February 10, 2010 - 03:22 PM
+2 i have 3 gallons of it in the garage :ride:
  • lexustbs
Posted February 10, 2010 - 05:23 PM
Simple Green is where its at. I dillute mine 60-40water and it works great. I dont like full strength as it seems to not bubble up as well. On some stuff we use at work, dilluted works way better than full strength, so I am a believer in the dillution ratios on the bottle..... Ill pass on the WD40 though. :ride:
  • greco3x
Posted February 10, 2010 - 06:03 PM
i fill my bottle up a little under half way, the rest water
  • sycraft
Posted February 10, 2010 - 06:53 PM
Works great, easier on metals than Simple Green. It is available now
http://www.magicbubblesproducts.com/
  • samras121
Posted February 10, 2010 - 09:23 PM
def simple green but if its stained, get brake cleaner, it works amazing!
  • awfulallen
Posted February 11, 2010 - 06:00 AM
I use a product called Awesome. Get it from Dollar General store. it is cheap and works great! Best thing is it doesn't eat the oil out of the plastic. Simple Green will eventually fade the plastic. Another point for Awesome is it doesn't leave any surface residue which makes it great for goggle lens also!:ride:
  • greco3x
Posted February 11, 2010 - 10:17 AM
cant beat the dollar store. i just bought some foam brushes at the dollar store for my resin. brushes are a one time deal with resin so i go to the dollar store
  • tke961
Posted February 11, 2010 - 10:21 AM
Which Simple Green product are we talking about? I've seen the all-purpose cleaner and I know they make a car wash soap too.
  • Charlie C
Posted February 11, 2010 - 11:14 AM
A friend of mine gave me a couple of cans of Black Magic express spray wax. It's spray car wax. I got some on the black plastic of the car and it worked like armore all without the greasy film. I tried it on the plastics of the bike and everything washed right off the plastics with the power of a garden hose. I didn't try it on the engine, but I would think that it would be ok as long as it isn't dripping off. I made the mistake of putting it on the side number plates and it made them so slippery that I had to wipe it off with brake cleaner becasue he couldn't squeeze the bike with his legs. It shined it up real good and it goes on wet or dry. It doesn't dry to a haze like normal car wax.
  • greco3x
Posted February 11, 2010 - 01:42 PM
i dont have a pressure washer, so i think that soaking simplegreen on everything and then washing it off with the highest pressure of the garden hose i can get is just as effective
  • greco3x
Posted February 11, 2010 - 01:43 PM
btw im talking about the all purpose cleaner. i also use the car wash stuff too
  • 50IsTheNew25
Posted February 11, 2010 - 06:25 PM
I have been using Tide with Bleach (powder) for many years and you will be amazed at how clean it gets the bike. No soaking required. Everyone always asked why my bikes look so clean. I just spray down the bike with a hose (carefully) and wash with a car wash cloth. I use about 3/4 of the little measuring scoop that comes with the Tide with Bleach. It's mild but really gets the dirt and grease off. Works great on our Laundry as well :ride:
  • Skotten
Posted February 13, 2010 - 10:48 AM
If its really dirty I use a nylon micro fiber brush, then wash my bike with simple green, then let my bike dry, and then use silver polish on the alu and finaly a coating of teflon based spray oil. But if it just a little dirty compressed air, nylon brush and a rag. Try not to spray the linkage bearings, swingarm bearings, steering head bearings, wheel bearings ect. Dont forget to greasae up yer chain...
230 Fork swap Spring 2016 - options by usedtobefast
Steam/white smoke coming out of crf250r by Seth McKenzie
Dirt Bike   Make / Model Specific   Honda   CRF250R
Thoughts on air forks for the XCs? by GlennE
Dirt Bike   Make / Model Specific   KTM   KTM 2-Stroke
  • Hot  26 replies
Honda CRF250R 2017 by Chris.GVS
Honda CRF250R 2017
  • 0 reviews
2004 CRF250R HEADLIGHT by fsmith1221
  • 4 replies
