Water in oil
3 replies to this topic
  • Gavindobson1
Posted February 08, 2010 - 12:05 PM
Please bear with me I'm still a newbie at this.
After washing down the bike and checking it out i noticed milky white oil on the rotor nut plug. I suppose water can enter as its only a plastic screw but not sure how oil got there as i was under the impression it was sealed off from the engine oil. please tell me if I'm wrong. No white oil on dipstick, i even drained a bit of oil off and it was clean.
Any help would be appreciated
  • Ebola
Posted February 08, 2010 - 02:05 PM
The flywheel area is wet, as in it shares oil with the rest of the motor.
  • Butta
Posted February 08, 2010 - 07:07 PM
Check your coolant level, drain and refill (or flush as necessary) the oil and keep a close eye on it to see if you see the water getting back into the oil over use.....
  • ch_250
Posted February 16, 2010 - 03:16 PM
It could also be your impeller shaft seals
