Suspension Help
9 replies to this topic
  • ROB450F
Posted February 07, 2010 - 06:52 AM
Recently brought a 06 yz450, the guy i bought it off was atleast 110-130kg
and the bike just feels wrong, soft, unstable and loooosseee!! :ride:
havent really got much experience with ride setups as my last bike just felt stable from the day i bought it.
is there any starting point i can go from rather then back to standard specs.
im 95KG (with riding gear) and 1.8m tall.
any help appreciated
Cheers
Rob
:lol:
Edited by ROB450F, February 09, 2010 - 06:39 AM.
Posted February 07, 2010 - 09:32 AM
Do you know if he ever changed the springs from stock? At your weight (209 pounds), you're a bit heavy for the stock springing yourself, especially if that's your weight without your riding gear.
  • ROB450F
Posted February 07, 2010 - 09:39 AM
not sure if it has been changed, been reading the owners manual about settings etc, how can i tell if it's an original or not? should i be looking at a stiffer spring?
95kg is with riding gear, the bike has alot of sag n sits pretty low then plus my weight it seems a bit soft and not much return strenght
cheers
rob
Posted February 07, 2010 - 09:43 AM
Try doing these two things in order:
1: http://www.tootechra...ension_tips.htm
2: http://www.tootechra...pension Tip.htm
  • ROB450F
Posted February 07, 2010 - 10:30 AM
thanks mate! there a great help interesting to see if ive even got the right spring.
another quick question with sprocket ratio's, i mostly ride trails and the bike feels "laggy" in low rpm 3rd gear, and a bit short in second so im continously shifting from 2nd to 3rd, i;ve been told to try 14/47 set up? wats your thoughts? there standard sprockets atm.
cheers
rob
Posted February 07, 2010 - 12:59 PM
Stock gearing is 13/49, and for a lot of people, that works pretty well in a wide variety of circumstances. You might go to something lower, like a 13/51 or 52 if most of your riding is really low speed stuff. 14/47 would be like locking the bike out of low gear. Might work for super moto, but certainly the wrong approach for trail riding.
  • ROB450F
Posted February 07, 2010 - 05:13 PM
ok thanks mate, good to get some advice off someone who knows wat their talking about
thanks again.
  • ROB450F
Posted February 09, 2010 - 04:45 AM
ok just a quick follow up, to see if i understood correctly
Race sag;
bike on centre stand: 630mm
rider on bike: 525mm
sag: 105mm (which indicates that is good??)
Should i lower this to 95mm to make the bike turn sharper?
Spring rate:
bike on center stand: 630mm
bike free standing: 600mm
sag: 30mm (which indicates that is the right spring rating?)This is also 1mm within guide lines should i change the spring?
Also how about front suspention setting are there any guid lines for them
i found some on the website above just wonder is they suit trail riding?
cheers
Rob
:ride:
  • ROB450F
Posted February 09, 2010 - 04:53 AM
also the sprockets are 14/49 would changing it to 13/49 make a big impact??
cheers
rob
:ride:
Posted February 09, 2010 - 09:18 AM
Major. 1 tooth at the front is roughly equal to 3 at the rear with sprockets in that size range:
49/13=3.77:1
52/14=3.71:1
(49/14=3.5:1)
The stock suspension settings are listed in the manual. A suspension set up guide is here:
http://motoman393.th...suspension.html
All of the links I've posted here, and one to download manuals are in the Common Threads Sticky.
