2007 Head Pipe
4 replies to this topic
  • danZ73
Posted February 07, 2010 - 05:07 AM
So I have had a White Bros Aluminum Pro on my bike for a couple years. The silencer has seen better days. My question is if I put the WB head pipe which is the lowboy type header on my stock silencer will that improve my low end at all? And what improvement will a slip on with the stock header do? any recommendations?
thanks
  • mywifefarts
Posted February 07, 2010 - 12:06 PM
I think if I were you being that you've already got the stock silencer I'd try it and see. It won't cost you anything and it can't hurt.
  • mywifefarts
Posted February 19, 2011 - 10:07 PM
Just sifting through and deleting old subscriptions to threads and came across this one. I'm wondering if you had any luck testing the White Bros. head pipe with stock silencer.
  • Family Man
Posted February 20, 2011 - 07:39 PM
The is no way it would fit, without cutting/welding the Wb header. the WB header is way way longer that the stock header.
  • mywifefarts
Posted February 20, 2011 - 09:37 PM
A few winters ago I bought a WB system from a fellow TT member for my '07 and While the bike was apart in my back bedroom for the winter I bolted up the WB Header to my stock selencer. The extra length actually compensated for by the larger lower hanging bend at the front of the frame. Obviously I had no reason to try this combo but am still curious.
  • Hot  50 replies
  • 9 replies
  • 10 replies
  • Hot  36 replies
