Clutch Cable / ASV
2 replies to this topic
  • joehonee
Posted February 06, 2010 - 03:10 AM
I am doing a little cleanup work on an 01 426 I just bought and found that the clutch cable was adjusted all the way out on both ends. I bought a replacement cable and found it to be the same. The prev owner had put an ASV lever on it and I believe this is the source of the problem. The perch/lever marriage is pretty sloppy. Did the ASVs require a specific perch or barrel adjuster. Could a worn clutch (it does not slip) lead to this? This model does not have any mid adjuster.
  • katoom08
Posted February 06, 2010 - 06:28 AM
I read in the forums that ASV will supply a barrel extension if you call and ask.
Katoom
Posted February 06, 2010 - 07:50 AM
As the clutch wears, free play is lost, so the adjuster moves in as that happens, not out. Check on the extension mentioned.
  • Hot  50 replies
  • Hot  28 replies
  • Hot  47 replies
