Helmet lights ?
14 replies to this topic
  • IrideWR
Posted February 05, 2010 - 03:02 PM
I was thanking of buying the trail teck lights but I whould like to know if there worth it or if thers better out there?
  • Family Man
Posted February 05, 2010 - 03:56 PM
The trail tech scmr16 light is top of the line. The Cyclops Solstice is also top of the line. As far as I know they are both the brightest lights available, equally bright. I think Im leaning twords the solstice at this point, but both lights are worthy contenders...
  • OUTERLIMITS
Posted February 05, 2010 - 05:28 PM
What do you need it to do, be a suppliment to your headlight or be the main light? If the main light then the two recommended above are the call. I believe the hid versions are about 30 watts. These are large.
I needed something to suppliment my headlight and am a big fan of this one. It rocks the house for only 10 watts of input.
http://www.thumperta...ad.php?t=817387
  • jrmxrc
Posted February 08, 2010 - 07:44 PM
If you want a great light for cheap do an internet search for a magicshine bike light, it comes with a 3 hr battery,charger,and a tiny light all for about 90.00 it has the same led emitter as the cyclops 10 watt.It is super brite and I use mine all the time for night rides.I even used it racing the baja 1000 this year and i was very happy with it.The best place to get one is www.geomangear.com he takes care of his customers
  • OUTERLIMITS
Posted February 09, 2010 - 09:05 AM
Good pull jrmxrc. Did you use a helmet mount, if so did you mount it on top? It looks like the helmet mount that they offer is meant for the top of a bike helmet and would only adjust on one axis. If chin mounted you really need to be able to adjust two ways else the light will point too low.
  • jrmxrc
Posted February 10, 2010 - 07:48 AM
The Magicshine pivots on its base so its easy to aim.I did use it as a chin mount and the mount straps on in seconds and stays put.
  • Baja Designs
Posted February 10, 2010 - 12:49 PM
Here is our New LED Helmet
https://www.bajadesi... Light Base Kit
  • kingjewells
Posted February 10, 2010 - 02:28 PM
[QUOTE]The trail tech scmr16 light is top of the line. The Cyclops Solstice is also top of the line. As far as I know they are both the brightest lights available, equally bright. I think Im leaning twords the solstice at this point, but both lights are worthy contenders... /QUOTE]
+1 I prefer the mounting for the Soltice
  • nscmj3
Posted February 11, 2010 - 12:24 AM
Have had great success with my trail tech. No complaints and super bright.
  • henrics
Posted February 13, 2010 - 10:22 PM
http://www.dealextre...ls.dx/sku.25149
  • red_rider_elsinore
Posted February 16, 2010 - 03:28 PM
Does the light give you option to run off the bike's power? During summer in the desert we ride from dusk to dawn.
  • jrmxrc
Posted February 16, 2010 - 05:13 PM
The magicshine should only run on a max of 8.4 volts but I have heard of people using 12 volts.I wouldn't do it myself.I believe you can run a resistor in line to reduce voltage but I don't know what size.
  • panaman
Posted February 17, 2010 - 06:31 AM
I thought about buying one of these flash light mounts for 12 bucks and mounting it to my viser
http://www.batterysp...elmetlight.aspx
  • tacotory
Posted February 21, 2010 - 06:51 PM
+1 I have the trail tech lights, and with the stock headlight you can ride at full speed at night. Great product. Nothing against the others mentioned.
  • Baja Designs
Posted March 01, 2010 - 04:33 PM
If anyone is interested in the new Baja Designs Strykr we are doing a TT group buy on it right now. Check it out and let us know if you have any questions about our system.
http://www.thumperta...ad.php?t=880861
