I'm Kieth...........I'm a TT addict. I'm 43, 5'10", 220, current league leader in Racquetball @ Long Beach LA Fitness club after 3 weeks.
Thanks to my sponsor,
Motorex Oils
I ride So Cal deserts and mountains as well as central CA mountains and trails.
Intermediate rider on open fast stuff, advanced on single track and techy stuff.
1998 XR 400
416 piston, 10:5-1 compression
3 angle valve job
Cleaned up ports
Barnums low-mid range cam
Edelbrock Quicksilver pumper carb
Uni air filter
Side air box cover screen mod
All motor work and suspension work by Barnums
Upgraded kick starter shaft and gears to 1999 model year specs(1mm thicker diameter)
Stock header pipes, ground welds, White Bros E series with 12 discs, quiet core insert
White Bros ignition kit
200 watt stator
Baja Designs kit
PIAA dual baja light system
Barnums suspension revalving with
Eibach springs, front and rear
Shaved stock seat, 2nd tall seat with Baja Designs tall seat foam
IMS floorboard like footpegs
O-ring chain
14/45 mountains, tech stuff, 15/45 desert rides
Renthal CR bend bars
Rally Pro ll handguards
Pro grip gel grips
Dunlop 606's,
Pirelli MT 21's,MT 83's,
Heavy duty tubes, front,rear
Garmin GPS 76-S hardwired, Touratech mount
IMS 4.3 gallon tank
Moose rollchart holder, lighted (radio shack indicator bulb hardwired)
Thumpertalk front fender decals
