09 YZF 450 steering stem torque?
4 replies to this topic
  • Gunner354
Posted February 04, 2010 - 06:26 PM
Looking for the torque spec for the steering stem. Need to grease bearings and need torque. Don't have manual.
  • gtguy
Posted February 04, 2010 - 06:40 PM
I've found Yamaha sets them at 9 1/4 turns in from the factory. That's how I set all of mine when I put them back together.
  • Gunner354
Posted February 04, 2010 - 07:19 PM
What? There is a torque spec. for the upper triple clamp nut or steering stem nut.
  • 426 NOOB
Posted February 04, 2010 - 07:38 PM
The manual is in the common thread sticky. Its something like 35ft/lb then back off a full turn then torque to 5ft/lb. Dont quote me get the manual.
Posted February 04, 2010 - 07:54 PM
The manual can be downloaded here:
http://www.yamahaown...ook.com.au/?r=0
When setting the bearings, run the ring nut down to around 25 ft/lb and turn the stem a few times to square everything up, then back off the ring nut to zero torque and set it at 5 ft/lb (60 in/lb). Then slip the fork tubes in place to line up the top clamp, drop the top clamp on and torque the crown nut to 105 ft/lb. This will noticeably tighten the feel of the head bearings.
  • Hot  50 replies
  • Hot  47 replies
  • Hot  36 replies
