2000 -vs- 2001 headpipe
3 replies to this topic
  • Boomer
Posted November 20, 2000 - 03:38 AM
Guys,
Because there is no real power gain, and especially NO HEAT SHIELD on the aftermarket products, I want to go with a 2001 headpipe for my 2000 model - just to gain access to the oil filter cover (bolt).
If anyone changes their 2001 system, I would be interetsed in their headpipe. I eyeballed a 2001 at a dealership, and it looks like the connect points to the muffler are the same.
... just an inquiry.
thanks,
Boomer
  • YZThumpa
Posted November 20, 2000 - 06:42 PM
If you are just looking for access to the oil filter, I was told that you can loosen the pipe, rotate it enough for clearance, and tighten it in this position. Haven't tried it on my 2000 yet. They said it just sticks out a little more and is more prone to taking a blow if you go down. Anyone done this, or is this a bonehead idea? I did see it on one bike. Saw the dent, too.
  • techman
Posted November 20, 2000 - 08:48 PM
You can't leave it rotated out and tightened because the headpipe flange won't sit flat on the cylinder mating surface. When you re-align the pipe after an oil change, it's how the flange flattens onto the cylinder that aligns the pipe, followed by tightening the pipe-to-pipe clamp. So the short answer is no.
  • Scott_F
Posted November 21, 2000 - 08:36 AM
Techman is exactly right. You will end up with an exhaust leak and a popping machine.
Scott F
  • Hot  30 replies
  • Hot  38 replies
  • Hot  36 replies
  • On January 15, 2017
  • Hot  50 replies
