Brake Help after bleeding
3 replies to this topic
  • coxr650l
Posted February 01, 2010 - 01:34 PM
On my 09450 I installed a brake light switch, replacing the banjo bolt on the rear master cylinder. The rear brake still worked after install, but I decided to bleed it anyway. I used a syringe and back bled the line. After I got done there is no brakes at all, ie pedal dose not engage the brake, even after pumping several times.
Any suggestions?
Thanks
  • coxr650l
Posted February 01, 2010 - 02:23 PM
Nevermind, got it figured out. Had air trapped by the banjo fitting.
Thx
  • phynx
Posted February 03, 2010 - 09:57 PM
:ride:
Thx
  • Ripter
Posted February 04, 2010 - 08:42 AM
I had an Aprilia that you needed to take all of the parts off of the bike and turn them upside down, sideways, stand on your head and sing a special chant to Itally to get all of the air out. Thankfully these aren't that bad!
