2008 yz450 Engine quit PLEASE HELP
5 replies to this topic
  • rubberband-man
Posted January 31, 2010 - 08:10 AM
I was riding at the track yesterday, landed a big table---on the gas when i touched down, and suddenly i lost throttle response and the engine bogged down until i stopped, at which point i pulled off the track and can now not get the bike to start. I noticed my oil drain plug by the shifter was loose and leaking some oil, but i tightened it up and the leak stopped, checked the oil and there is still oil, but it was low. I added oil. i try to kick it, and it feels a little easier than it normally is to kick it, but it's always been really easy to kick start. it's a 2008 yz450. oh yes--there was no smoke coming out of anywhere, but when i tried to kick it, smoke would come out of the tube that comes off the top of the engine and empties by the shift lever. Please help. Thanks
  • alwho44
Posted January 31, 2010 - 08:20 AM
check for fuel, (is the plug wet) check for spark, (pull plug ground to engine see if it sparks), check compression or do a leakdown test if you got spark and fuel
list of possibles is as long as your arm but above tests will cut it by 2/3.
  • Gunner354
Posted January 31, 2010 - 11:07 AM
Pull the left stator cover off and check 4 a stator bolt broken or broken coil wire. The 08 stator was mounted with 3 bolts and some people had problems with loose bolts or broken coil wire from excessive vibration. This was fixed with 4 mounting bolts in 09. Good luck!
  • 426 NOOB
Posted January 31, 2010 - 01:30 PM
It very well could be that your cam chain jumped time. When you came down on a load it may have skipped, this would also explain the easy kicking if the cams were not timed correctly. I would take the valve cover off and make sure they are dead on in time. If the bike has over 30 hrs it should have been replaced.
  • rubberband-man
Posted January 31, 2010 - 07:48 PM
i checked the spark plug first, there is barely a spark and it is pretty black. i'm going to get another plug tomorrow, then go through all of your suggerstions if that doesn't work. thanks for your help.
  • moto2000
Posted January 31, 2010 - 08:54 PM
Carb pop out of the boot/flange?
