HELP!! Need part # for AP plastic arm
3 replies to this topic
  • kevin1209
Posted January 29, 2010 - 10:18 AM
I have a 1998 WR400 with a Keihin Flat CR carb. While trying to clean the carb, the return action on the throttle started sticking worse and worse. I followed the arm down to the connection near the Accel Pump. There was a small crack in the black plastic arm. When I moved the throttle again the arm broke. I included a pic of the broken part. It is the black plastic arm that connects to the Accel Pump plunger rod, and also controls the spring for the throttle. I have looked extensively at the carburetor exploded view, and I cannot see which part this is. The diagram doesn't show that side of the carb. Please help!
  • kevin1209
Posted January 29, 2010 - 10:21 AM
The pic wouldn't show up.
Here's a link to the picture"
Thanks everyone.
  • BajaFool
Posted January 29, 2010 - 04:22 PM
How about this exploded view http://www.keihin-us...fcrmx_parts.pdf found at this link: When Keihin US opens, click on After Market. If this does not give you what you want, call Keihin US.
  • kevin1209
Posted January 29, 2010 - 06:42 PM
Thanks for the link. The part is ordered $21.00. I couldn't force myself to buy the new rod. $24.00 for something no bigger than a tiny allen wrench. Mine will do for now. They also wanted almost $6.00 for the little rubber boot that goes over the fitting. Isn't that considered statutory rape?
