valve check
4 replies to this topic
  • motodiver13
Posted January 27, 2010 - 04:53 PM
Is it possible to check valve clearance with the head off the bike? Thanks
  • Ebola
Posted January 27, 2010 - 07:00 PM
I would think so if everything it torqued down correctly. The cams might spin a little, so that might be an issue. Assuming you can keep them from moving, I don't really see why not.
  • Birdy426
Posted January 27, 2010 - 10:09 PM
Yes. That's what you do when you are building up a head to install.
  • Ebola
Posted January 28, 2010 - 06:13 AM
See, told ya.
  • motodiver13
Posted January 28, 2010 - 09:16 AM
Thanks. I wasnt sure if the timing chain needed to be attached, thought it might put some tension/deflection on the cams. I'll check before installation. Thanks again
