Rear tire on the front?
9 replies to this topic
  • brianpeerson
Posted January 26, 2010 - 09:26 AM
I need a set of knobby'ish tires for my DRZ 400SM. Problem is nobody seems to make a dirt tire for a front 17" rim. It looks looks I'm going to have to use a "rear" tire on the front of my bike. I would look into a new set of rims but money is an issue and I only need them for a 7 day trip in the mountains of New Mexico. My main question is , do you guys think a tire designed for the rear of a bike will work in the front? I know that front or rear they're all round and made of rubber but will it effect handling? If so how bad?
Thanks for the help!
  • MrBlahh
Posted January 26, 2010 - 09:50 AM
kenda trackmasters have a 17" front, will this fit? 70/100-17
I use them on my xr400, but in 21", they are not great on the road, but work pretty good offroad
  • KcDavis
I have seen people with SM's that have knobbies on them for trail riding. Aren't the front and rear tires the same all around, or is the front narrower than the rear? If the tires are the same size, than I would imagine that you would be good to go. If you do a search, or go to some of the bike forums (if you haven't already) you will find people who have put knobby tires on their SM's, and they can definitely lead you in the right direction.
  • Atrus96
Posted January 26, 2010 - 10:10 AM
You should be fine, all the stuff I have heard say rear tires are built to a higher standard and can be harder/softer. You may want to bite the bullet and call a tire store or better yet the manufacture if you fav brand
  • Layton
Posted January 26, 2010 - 11:15 AM
I didn't search very long and found this so one or more tire companies are making 17 inch front tires.
http://www.amazon.co...s/dp/B002PLASSQ
  • cleonard
Posted January 26, 2010 - 01:31 PM
This issue is the width. I think any 17's for the front will be narrow like the 70/100-17. I just don't see that working with the wide sumo rims. I have a feeling you will have to use a wide 17 inch rear knobby. The down side is the weight. It might make for some interesting handling. As long as you don't expect it to work like a normal 21 inch dirt only front tire you should be OK. I'm sure it will work better in the dirt than the slick sumo tire you have on the bike right now.
Try and find the lightest tire you can.
  • MrBlahh
Posted January 26, 2010 - 01:32 PM
dont the big adv bikes use them? like a big bmw, or a suzuki 650
  • cleonard
Posted January 26, 2010 - 01:49 PM
Some of those bikes run 19 inch fronts and perhaps ever 18's. I do not think any run 17's and remember that sumo rim is like 3.5 inches wide. You will need a 120 or so width at a minimum and that's going to be a 17 rear.
  • justbackitin
Posted January 26, 2010 - 03:18 PM
Some guys run Continental TKC-80's front and rear since they come in sizes close enough for supermoto wheels. Other than that look at Pirelli mt-60's or Avon distanzia's (lots of guys rave about the distanzia's on and off road).
  • brianpeerson
Posted January 27, 2010 - 04:42 AM
Yep....it's the width thats been messing me up. I figured the weight would be an issue.
  • Hot  28 replies
XR400 Rebuild (Partial) by BluntMachete
Dirt Bike   Make / Model Specific   Honda   XR250/400
Moving to thumper? by 2StrokeCruiser
  • 8 replies
Are my valves to tight? by jo3lp3
Dirt Bike   Make / Model Specific   Yamaha   WR/YZ 250F
  • 7 replies
Husqvarna Motorcycles Introduces New 701 SUPERMOTO & 701 ENDURO - last post by Bryan Bosch
