Fuel mixture screw mod, easy and cheap. 01 YZ
4 replies to this topic
  • Lota Fun R
Posted January 25, 2010 - 01:04 AM
Since I'm also into flying RC helicopters I happen to have these parts laying around..All I did was take a brass sleeve that is intended for the main blade and glued it to the screw, then glued that to a piece of plastic tubing and then a servo wheel screwed and glued on that. I used 6 min epoxy, sanded everything so it would bond. Since I wasn't sure how this would turn out I made sure not to get any epoxy on the end of the stock screw just in case it didn't work out I could still use the screw driver on it to adjust. The brass sleeve is aprox 12mm long and fits perfect, you could use anything that fits for this part or use your imagination and come up with your own.
As you all know it's a PIA to get a driver down there and adjust the idle mixture.
I didn't like the idea of having to pay $20 for this so I just customized mine.
I'll find out if it lasts. If it comes apart I'll drill a 1mm hole in it and use safety wire to hold it together.
Hope this inspires some of you to come up with solutions that aren't expensive and gets the job done. :ride:
Edited by Lota Fun R, January 25, 2010 - 09:30 PM.
  • Dave102429
Posted January 25, 2010 - 03:55 PM
Pssst...it's called a fuel mixture screw, not idle screw. And very cool BTW.
  • Lota Fun R
Posted January 25, 2010 - 09:31 PM
Fixed. Thanks for correcting my terminology.
  • Lota Fun R
Posted January 25, 2010 - 09:50 PM
Here's a little more detail on the mod.
Showing the modified part, the brass collar, the plastic tubing I used and a servo wheel. I used a wood screw to attach the servo wheel as well as epoxy.
Posted January 26, 2010 - 08:03 AM
Don't worry about it - it's called about six different things, all of them correct.
Motocross
  • Hot  491 replies
  • On January 15, 2017
  • 0 replies
  • 10 replies
