Help, Engine wont start. (yz426)
6 replies to this topic
  • smith6653
Posted January 24, 2010 - 04:37 PM
I bought this bike and it was not running. Seems like it has very little compression. I am just wondering where to start. Guy i bought it from said it just needs a cylinder/piston. Any suggestions will be helpful. Thanks (Its getting spark but will not even attempt to run.)
  • 642MX
Posted January 24, 2010 - 04:39 PM
I'd check the timing and valve clearances first.
  • smith6653
Posted January 24, 2010 - 05:40 PM
I've checked the timing to the best of my knowledge. Not for sure about valve clearances. Would a bad cylinder/piston or rings cause it to not even try to run?
  • pembell
Posted January 25, 2010 - 11:23 PM
If there's no compression, it won't fire, so it won't run.
When you press down on the kickstart, do you get to a point where the kickstart won't go further, ie a hard point? If not, then you've got no compression, so either the rings or valves or maybe the valvelifter could be a problem.
  • Rude Riders
Posted January 25, 2010 - 11:29 PM
be sure to check your valve clearances and timing chain tightness this can cause low compression and no starting. Then go from there
  • smith6653
Posted January 26, 2010 - 05:04 AM
theres definitely no hard point when i press the kickstart, its looks as if the valves are operating correctly, i guess i will check the clearances and if that doesnt work move on down to check the rings/cylinder.
  • tech24
Posted January 26, 2010 - 05:09 AM
+1 on valve clearences, if a valve or valves are hanging open this will cause your problem.
  • Hot  36 replies
  • Hot  50 replies
  • Hot  38 replies
  • 10 replies
  • On January 15, 2017
