'06 front axle nut
7 replies to this topic
  • cbwood
Posted January 23, 2010 - 09:47 AM
Seem my front wheel axle nut is aluminum. No way to get to the 75 ft/lbs of torq. Any one else have this?
  • Smokeslider
Posted January 23, 2010 - 10:45 AM
What's the problem exactly?
  • SAthump
Posted January 23, 2010 - 11:00 AM
I only put 60lbs on them, and I replaced the aluminum with the older model steel ones. I have had two nuts bust from trying to use the manuals torque.
  • cbwood
Posted January 23, 2010 - 08:50 PM
Just trying to see if people are really leaning on these nuts to 75#. Theres no way I could get close and not strip it out. Is it a bug deal to just snug it up and set the axle clamping bolts as advertised. How far back to get the steel ones?
  • husqy360
Posted January 23, 2010 - 09:19 PM
i tourqe to what the manuals sey, never had a problem.
Posted January 24, 2010 - 08:34 AM
Yes, the nut is aluminum, but I've never used a torque wrench on an axle nut that I can recall, and never had a problem with either stripped axle nuts or wheels coming loose. I check mine a while ago when this subject came up, and it looks like I end up setting them to around 50-60 ft/lb. I don't think it really needs to be tighter than that, but that's me.
But I do use a torque wrench on the nut at the steering stem, which is also aluminum, and that one is set at 105 ft/lb. Never had a problem there either.
  • cbwood
Posted January 24, 2010 - 09:48 AM
That sounds more along the lines of what I'm finding. Thanks.
A bit of a digression or maybe a new thread but did find some weld splatter in the head tube. Stuck in the grease on the lower bearing. Give the whole thing a good cleaning before repacking.
Edited by cbwood, January 24, 2010 - 12:06 PM.
  • myoung
Posted January 24, 2010 - 01:54 PM
Stripped the original on my '09 and went to steel, fixed!
  • 9 replies
  • Hot  113 replies
Motocross
  • Hot  491 replies
