fork height
4 replies to this topic
  • ltrosson
Posted January 21, 2010 - 08:57 PM
Need a little help, 08 450, is raising the forks up to the first line on the fork tube approx. 5mm. and is sag at 108 approx. 4.25 inches. Just had suspension done and these are the starting recommendations. thanks alot
Posted January 21, 2010 - 09:17 PM
The conversion form metric to English is based on 1" = 25.4mm. 4.25" is 107.95 mm. You should be able to measure the fork yourself, but yes, the first machined groove is at 5mm.
If you have any complaints regarding understeer (front end push) on corner entry, try less sag, like about 98mm.
  • ltrosson
Posted January 21, 2010 - 09:36 PM
Thanks Grayracer,with sag at 98 do you suggest raising the fork tubes 5mm?
Posted January 21, 2010 - 09:45 PM
Yes..
  • YamaLink
Posted January 22, 2010 - 08:24 AM
Yeppers. Set (or in your case, reset) sag and THEN make changes to the forks. And properly torque those fork bolts; too tight, especially the lower ones.
  • Hot  50 replies
  • Hot  113 replies
  • Hot  47 replies
