2005 wr 450 HID kits.
6 replies to this topic
  • TRUE_2_YAMAHA_001
Posted January 20, 2010 - 10:30 PM
So im sure that you guys have seen the HID conversion kits, i would like to run one, but i am not sure if i need to have my stater rewound before i do so.
Thoughts or ideas anyone??
Thanks,
Eric.
  • freerider_australia
Posted January 21, 2010 - 12:50 AM
the wr put out ac voltage i suspect that hid needs a stable dc 12 volt supply unless they are designed to go on the ac supply
  • cat0020
Posted January 21, 2010 - 12:15 PM
For 2005 model you should be okay, if you can't use the OEM headlight wiring to connect to the HID ballast, connect the ballast directly to the battery with a relay, that should work.
  • PBDBLUE
Posted January 21, 2010 - 02:21 PM
Huh???....As far as I know the electrical system in the WR is the same from 2003 - 2009. The oem headlight runs on AC and the DC circuit that charges the battery only puts out about 2 amps. It's woefully inadequate to supply an HID light. You need at a minimum to mod the stator and add a rectifer/regulator.
  • 123BigcoopDawg576
Posted January 21, 2010 - 03:03 PM
+1 :banghead:
  • TRUE_2_YAMAHA_001
Posted January 21, 2010 - 05:18 PM
thanks for that guys.
so would you rewind the stater, or just buy a bigger one?? :banghead:
  • KennyMc
Posted January 21, 2010 - 06:42 PM
Baja Designs has a great tutorial. Or for $30, they will do it for you. You will also need to buy a regulator/rectifier.
http://www.bajadesig... Stator Mod.pdf
