WR400 wiring prob. pic
10 replies to this topic
  • Ebola
Posted January 18, 2010 - 08:21 AM
Would someone be so kind as to post a pic of their stock wiring under their seat? Mine was hacked when I got it and have no reference to fix the problem. I would like to make my tail light work again. I checked the wiring diagram and was confused that the brake light wiring harness had 2 wires, but the bike has 3. Below is a pic of what mine looks like. TIA
  • cwcarter
Posted January 19, 2010 - 04:50 AM
Blue is tail light.
black is earth.
yellow would be brake light.
The other 2 black wires leading to the right of the bike should go to a brake light switch.
So if you plug in the blue and black wires you should have a tail light. check the bulb aswell, it should have 2 filaments.
  • Ebola
Posted January 19, 2010 - 07:14 AM
I checked the bulb and it is dual filament. I must be missing some kind of junction wire to bring 2 wires into one because I have 3 wires coming from the tail light and 4 wires on the bike side.
  • cwcarter
Posted January 19, 2010 - 01:08 PM
Thats right. Easy to make one.
  • Ebola
Posted January 19, 2010 - 01:42 PM
I suppose so, but still don't know what to connect to what. Electrical has never been my strong suit. Hence the request for a pic.
  • AZWFO
Posted January 19, 2010 - 06:28 PM
Here's my 99. The green and white (going left and down) go to pressure switch at the rear brake. Ignore the 3 fuse holders-their for the horn and other stuff.
  • Ebola
Posted January 19, 2010 - 08:30 PM
Thank you so much for taking the time to post the pic! That helps a bunch. Cheers!
  • cwcarter
Posted January 19, 2010 - 09:20 PM
  • Ebola
Posted January 20, 2010 - 06:58 AM
And thank you for the wiring diagram. Thanks for responding guys.
  • pablo83
Posted January 20, 2010 - 02:12 PM
Most of the time whoever installs the break switch will splice another wire of the blue wire. It looks like your blue wire has had some elec tape added. Follow the wire farther back to see if there is another wire spliced onto it. If not then pull back that elec tape to see if the extra wire was covered up at some point.
  • Ebola
Posted January 20, 2010 - 05:26 PM
Good point, thanks Pablo.
