2008 Yamaha YZ450f
11 replies to this topic
  • mx566
Posted January 16, 2010 - 09:32 PM
I have a 08 YZ450 and have always had problems with the turning of the bike in corners. I remember seeing some where that a certain mm offset top triple clamp will help this trouble but cant remember what it was. Any suggestions?
  • Wes Woodin
Posted January 16, 2010 - 09:53 PM
I believe out on 24 mm triple clamps, raise the forks in the triple clamps the lengthen the wheelbase be moving the wheel back. this is what I've heard
  • MikeyT750
Posted January 17, 2010 - 06:41 PM
I just did it. Raise the forks 5mm. You won't believe the difference
  • YamaLink
Posted January 19, 2010 - 08:06 AM
Yep, a few mm makes a huge difference.
I presume your rear sag is set and the bike is properly sprung? As you know a tiny change to sag will affect the front a lot more.
Anyway, glad to read you're happy with the turning. The 08 is a great cornering bike!
  • DMC707
Posted January 19, 2010 - 05:00 PM
On this bike, it helps me to sit further forward than would normally be my comfort zone. I put a bump seat on as well, and this keeps me up there a tad better --- no other changes but remembering to do that and it cornered better, before it wanted to crawl out of its line in some turns
  • ubu
Posted January 19, 2010 - 09:30 PM
I played with the fork height a little, but ended up leaving them right where the groove lined up with the top of the clamp. I'm slightly tall at 6'2". I changed to a Windam bar. I also changed the front tire to a D952 and went to a 110 instead of a 120 in the rear when the stock one was worn out. My sag was fine, so I left it alone. I think the different bars help me get forward a little more and keep my elbows up better. The 110 tire in the rear is probably just mental, but I feel like I can lay it over better. The stock front tire sucks, IMO.
  • mx566
Posted January 23, 2010 - 12:20 PM
I decided to go with a pro circuit 22.5mm offset top triple clamp but i'm being told i need the bottom clamps to for this to work. Is this right? Do i need both the top and bottom clamps for this to work?
  • Greg_T_M
Posted January 23, 2010 - 01:30 PM
You can take this for what it is worth. The testing was done on a 2007 so may not be apples to oranges, but they were trying to improve turning by changing tripple clamp offset.
http://www.motocross...6D7B09F282347AD
  • BlackT5
Posted January 23, 2010 - 02:14 PM
Here is my setup and it rocks so far. Super stable for me. It does step out but its mellow enough to deal with. I naturally sit as far forward as posible, the my legs on the shrouds. Elbows up.
952's front and back. Would like to go to MX51's when these die. I put the 120 size rear on but its larger than the stock 120. I think I will go down to 110 on the next tire.
Sag is 97mm.
Windam Bars.
Top grove in forks even with top of clamp.
Rear axel all the way back. Just forward enough to keep the chain slack right
Posted January 23, 2010 - 07:29 PM
Yes, if changing the offset, you MUST use both the upper and lower as a set.
  • FinchFan194
Posted January 23, 2010 - 07:39 PM
I have talked to quite a few that said there was a big improvement in the handling of the 08 vs the 07. I know after some suspension tuning and setting my sag mine turns about 5 times better than my 04 ever dreamed of.
  • Greg_T_M
Posted January 24, 2010 - 05:56 AM
Sounded like the 08 is suffering from the same problems as the 07. I haven't rode an 07 but have an 08 and see the same issues. I struggle in loose hardpack where I'm afraid to commit to leaning in and carrying much speed. Body position is very important in those situations as stated before. If I'm getting decent traction I rarely get beat out of a corner. I'm working with Dave J to get my suspension set up correctly and getting a steering damper to hopefully improve confidence in some lower traction situations.
  • Hot  38 replies
  • Hot  36 replies
  • Hot  113 replies
