Additional headlights?
8 replies to this topic
  • ddialogue
Posted May 09, 2003 - 11:09 AM
Anyone added extra headlights to your WR's? We ride the sand dunes twice a year and extra lights would be killer for night riding. The WR headlight is plenty bright, but the fender blocks alot of it and I thought maybe some low wattage driving lights temporarily strapped to the forks (below the fender to fill in the black spots) might be a solution. I am electrically challenged so let me know what you think!
  • BrandonW
Posted May 09, 2003 - 02:00 PM
I am looking to upgrade in this area too.
I have a 55/65 watt bulb up front, and under a load, it spews out plenty of light, but low-speed single track when dark, is scary.
First off, I believe that the '98 WR stators are less powered than the newer, maybe something like 80 vs 120 watt output, or something like that? Is up-grading to a higher out-put stator a solution?
Also, a neighbor of mine is thinking that my rear light probably draws about 10 watts, and maybe 15 when I am using the brakes. He says that if we convert that over to LCD, the draw is reduced to 2-3 watts.
Are these the solutions to better lighting at night, or are there other directions?
Thanks!
  • captain_S
Posted May 09, 2003 - 03:08 PM
Yep brandon, you are rite about the lcd lights,they draw less power(i have been told they are real sturdy too!),now you guys may think this is a crazy idea but when i was watching the dakar rally on tv this year i saw a guy get help from some other folks when his lights got broke after a fall,he rode of into the dark with some spot lights taped too the top of his crash helmet!,looked real good (you go where you look remember)now i`m sure with a little bit of cunning this could be perfected to be mounted to the peak of a crash helmet(those little after market headlights should work ok)and plug it in just behind you at the rear of the seat!,what do you think? :)
  • oRGie
Posted May 09, 2003 - 03:15 PM
Yep brandon, you are rite about the lcd lights,they draw less power(i have been told they are real sturdy too!),now you guys may think this is a crazy idea but when i was watching the dakar rally on tv this year i saw a guy get help from some other folks when his lights got broke after a fall,he rode of into the dark with some spot lights taped too the top of his crash helmet!,looked real good (you go where you look remember)now i`m sure with a little bit of cunning this could be perfected to be mounted to the peak of a crash helmet(those little after market headlights should work ok)and plug it in just behind you at the rear of the seat!,what do you think? :D
I tink U arrr kRaZy :) muhahahaha
  • PumpkinHumper
Posted May 09, 2003 - 05:01 PM
You need more light? You need H.I.D. lighting. Its expensive but from what I hear it is the hot setup.
  • jasowiii
Posted June 02, 2003 - 06:54 PM
It's L ight E mitting D iode.
Not LCD!!!
I'd be interested in any info, links etc. on HID lighting systems. The stuff I have found looks big and heavy!
Does anyone know the output Watts/Amps of the 98 WR400 stator? :)
Jimmy
  • PumpkinHumper
Posted June 03, 2003 - 06:52 AM
Check these folks out.
Baja Designs
They have all kinds of lighting solutions. It aint cheep. But its bright.
  • Desracer
Posted June 03, 2003 - 07:56 PM
I have read that you can replace the stock bulb with an 85 watt HID bulb. I did ride in the dunes with the stock light and found it plenty bright. The problem I had was turning and not seeing where I was going, so I tried tapeing a flashlight to my helmet and it helped. I did buy a 3 bulb led unit for this but havent had a chance to use it. The HID bulb would be nice though.
  • ddialogue
Posted June 04, 2003 - 05:05 AM
HID just isn't in my price range for what I need. A helmet light seems to be a better (more affordable) solution. I have been looking at the Lead-Dog helmet light. Lead-Dog makes a great light that you can wire into your electrical system and mounts to the helmet. Adds 35 watts of halogen light to your system.
I changed out to an led taillight bulb. It works great and is durable and bright!
