how to check crank phasing
6 replies to this topic
  • 2007summit
Posted 13 January 2010 - 04:01 PM
have a 2007 skidoo summit x 800 and need to know how to check for a twisted crank
  • XC700116
Posted 13 January 2010 - 08:52 PM
best way to check it with the crank still in the motor is to attach a degree wheel for reference and use a dial indicator to check top dead center on each cylinder and at what angle on the degree wheel they each coincide with. The should be ver close to 180 degrees apart from each other.
  • 2007summit
Posted 14 January 2010 - 03:09 PM
so one piston is at tdc and the other one should be the farthest it can go down right
  • XC700116
Posted 14 January 2010 - 03:53 PM
yeah pretty much, there's always a tiny bit of tolerance involved but ideally you want exactly 180
  • 2007summit
Posted 14 January 2010 - 04:58 PM
ya must have twisted it pretty good there isnt much difference between the two piston but about a inch
  • XC700116
Posted 14 January 2010 - 08:04 PM
they are that close to each other?
like ones at TDC and the other is only an inch down the bore?
If so HOLY CRAP!!!! That's a dandy
  • 2007summit
Posted 15 January 2010 - 02:50 PM
ya thats what i thought the dang things still runs though very rough idle and backfires like no other plan on tearing it apart this weekend
