Why is the 426 hard to start after you stall it.
17 replies to this topic
  • PAKDXYZ
Posted January 13, 2010 - 03:39 PM
My 426 runs great, starts right up cold. Always starts first kick when riding if I use the kill switch when I stop, but if I stall the bike it can be a real bear sometimes to get started again. I know its notorious for this just wondering what the mechanics behind this would be, in other words why is it harder to start after stalling as opposed to using the kill switch???
  • meyermetal
Posted January 13, 2010 - 03:44 PM
Because it is missing 24cc :banghead:
Actually it was designed at the earliest stages of 4-Stroke development
They have figured the starting problem those early first bikes. Adding auto decompression on the cam lobes was a huge help
Posted January 13, 2010 - 04:13 PM
The actual reason is that it's more prone to flooding/fouling the plug when stalled or tipped over.
  • PAKDXYZ
Posted January 13, 2010 - 04:29 PM
I was thinking it had something to do with flooding, but was just curious.
Thanks
  • Mikeb12
Posted January 13, 2010 - 04:31 PM
it should not be hard to start. my partner ride s 426 and it fires hot or cold. make sure your hot start is working properly.
  • PAKDXYZ
Posted January 13, 2010 - 04:44 PM
hot start is good, it was replaced about a year ago. And it fires hot fine but only if it is shut down with the kill switch
  • 642MX
Posted January 13, 2010 - 06:06 PM
Whats your jetting specs?
  • PAKDXYZ
Posted January 13, 2010 - 06:11 PM
stock jetting. Fuel screw 1 3/4 turns.
  • 642MX
Posted January 13, 2010 - 06:13 PM
First step is to get a JD jet kit and wire the accelerator pump. The stock jetting is horrible in the 426.... or at least it was in mine.
  • VFRCaptBob
Posted January 13, 2010 - 10:56 PM
Where is a good place to order a JD jet kit? I just started riding an 01 426 and really like it. But it really bogs down when climbing at higher altitudes. I think the hard starting after stalling or falling is mainly flooding. I pull the decomp. lever and give it several kicks to clear out the cylinder if it doesn't start right away. Then try and start it. Works some times.
  • rufusz
Posted January 14, 2010 - 02:58 AM
Lean out the pilot a little bit (with the fuel screw)...has huge effect on restarting hot (at least on my bike it does)
  • roylo
Posted January 14, 2010 - 04:25 AM
All four strokes are hard or harder to start after a stall, not just the 426.
  • 642MX
Posted January 14, 2010 - 08:30 AM
I can cart wheel mine, let it lay upside down for 5 minutes, pull the hot start and it will start on the 3rd kick. When everything is working properly (jetting) they start up quickly no matter what you do.
  • 642MX
Posted January 14, 2010 - 08:31 AM
Where is a good place to order a JD jet kit? .
The TT store use to carry them or you can order straight from JD.
Posted January 14, 2010 - 09:50 AM
But when you don't cartwheel it, it still starts better than that, doesn't it?
  • 642MX
Posted January 14, 2010 - 12:28 PM
She always lights by the third kick. :banghead:
Posted January 14, 2010 - 04:39 PM
Stop dodging. Does it or does it not normally start better if it hasn't been flopped on the ground?
  • 642MX
Posted January 14, 2010 - 06:38 PM
lol... Actually with the Rekluse Pro, its very hard to stall it. (but possible under the right conditions)
It makes no difference if its been crashed or not. 1-3 kicks and its starts. If its been crashed, I pull the hot start... if its cold i pull the choke.... if its not flooded or cold, I just kick it. This applies to the 290 too.
:banghead:
  • Hot  47 replies
  • 10 replies
  • Hot  113 replies
Motocross
  • Hot  491 replies
